Activity › Forums › Boris FX Particle Illusion › When exporting TGA format files cant see original background picture..
  • When exporting TGA format files cant see original background picture..
    Posted by Ki Young woo on February 10, 2006 at 6:33 am
    Hello ^^
    I imported one image picture on new layer for make TGA files with original picture`s transparency
    after that I made some moving partikle on it
    And export TGA files of caurse checked ‘save alpha channel ‘
    but the result was net good enough that i couldnt see well original picture
    it had transparency but picture was unclear
    so I did other ways which I could in checking other options
    but also other result were not good
    How can I get both good result with original picture with that`s transparency
    and new partikle to TGA files?
    I will really happy if I can get answer
    thank you have a nice day
    kitan98@hanmail.net
    have a nice day
    Aharon Rabinowitz replied 20 years, 7 months ago 2 Members · 1 Reply
  • Aharon Rabinowitz
    February 12, 2006 at 3:33 am
    When you export images of particles, the only alpha channel that’s preseverd are those of the particles, not the BG image.
    You are best rendering out the animation with the BG turned off, and with preserve alpha channels set to on – and then compositing the particles and your BG in a compositing program like After Effects (or whatever you use).
    Otherwise, keep the BG turned on, and don’t export with an alpha channel, if you want to see your BG image.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
