Activity Forums Adobe Premiere Pro When exporting a project the resolution becomes fuzzy.
  • When exporting a project the resolution becomes fuzzy.
    Posted by Randy Gallagher on January 8, 2013 at 10:19 pm
    Good evening I am in need of a little help and am still sort of green in the areas of editing film. I had some relatives send me some files to edit together for them and I have done such and when I go to export a cut of it the video seems to become more fuzzy than when I started.
    Is there a certain export format that is better than the rest?
    These videos were shot on a consumer handicam style camera and I understand that it won’t be amazing but it just comes out a little rough.
    What can I do to make it look better? Any help will be greatly appreciated as I want to learn to make better projects as I continue my work.
    Ivan Myles replied 13 years, 8 months ago 2 Members · 1 Reply
  • Ivan Myles
    January 9, 2013 at 12:32 am
    Please provide some information regarding the following:
    Source footage: codec, wrapper, bit rate, frame rate, resolution
    Editing sequence: frame rate, resolution, and any effects applied
    Output file: codec, wrapper, frame rate, resolution, quality settings, bit rate, etc.
    Video can lose sharpness as a result of over-compression and trans-coding from one codec to another. Try to export the edited sequence using fairly light compression settings including a moderate to high target bit rate, 2-pass encoding (if available), moderate key frame distance (2-4 seconds), and the same codec as the source footage, if possible.
    I tend to treat encoding as an iterative process. Try taking a few short clips (5-10 frames each) that include the fuzzy footage, copy the clips onto a new sequence, and export several test files using different codecs and output settings. Generate 3-4 files for each codec using a range from low-quality, low-bit-rate to high-quality, high-bit-rate. Import the test files and stack them on top of the original footage. Turn each track on and off to compare the same frame on the different files. After viewing a few frames you should get a clear direction on which settings work best for your footage.
