Activity › Forums › Adobe After Effects › When Ever I Preview And Render Im Getting Alot of Glitches! (read for more info)
  • When Ever I Preview And Render Im Getting Alot of Glitches! (read for more info)
    Posted by Steven Farrugia on June 6, 2010 at 5:14 am
    Just think of it as my footage is going *giggity Gigity* its glitching from frame to frame. my camera is canon fs100
    and i converted the file MPG to AVI simply be renaming it..
    i would try importing with a diffrent file type but im not sure which one…
    Im using adobe after effects cs3
    4gb ram
    Steven Farrugia replied 16 years, 3 months ago 3 Members · 6 Replies
  • Georgios Soumelidis
    June 6, 2010 at 11:57 am
    “Just think of it as my footage is going *giggity Gigity* its glitching from frame to frame”
    If it goes ok at first frames and in a few later the “giggities” starts and getting worst then it could be your frame rate. Check your frame rate of your footage to be the same to the one your camera had when you took the shot… could be that
    “and i converted the file MPG to AVI simply be renaming it.. ”
    ..why? Be more specific.
  • Todd Kopriva
    June 6, 2010 at 8:13 pm
    Why would you do this?
    The file-name extension tells software what kind of file it is. That tells the software, for example, which piece of software to use to open, import, and decode the file.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Steven Farrugia
    June 7, 2010 at 8:58 am
    theres this way to change a file just by renaming the .avi or .mpg so i can put it into CS3
    coz it wont go into cs3 as an mpg
    and the frame rate is set as the same..
  • Steven Farrugia
    June 9, 2010 at 9:41 am
    Ahem..
    https://www.youtube.com/watch?v=-N0B4Q57vUU
    there you go mr “expert”!
  • Todd Kopriva
    June 9, 2010 at 3:47 pm
    Just because a kid posted a video on YouTube showing you how to do something, it doesn’t mean that it’s a good idea or that it works (well).
    I am telling you as a member of the team of people that makes After Effects that changing a file-name extension is not a good or supported way to do this. Changing a file-name extension makes it so that the wrong piece of software is assigned to the decoding task.
    To put it roughly, this is like getting a big couch through a small front door by chopping it in half and chopping the legs off. Yeah, you can get it in, but it won’t be as useful later.
  • Steven Farrugia
    June 10, 2010 at 10:26 pm
    -.- sorry!
    anyway ive worked out the problem xD
    i was using a bad file (avi)
    im using .mov now and its better.
