Activity Forums VEGAS Pro when events turn pink
  • when events turn pink
    Posted by Michael Hurwicz on September 1, 2005 at 4:18 am
    What does it mean when an audio or video event in the timeline turns pink?
    Sergio replied 21 years ago 5 Members · 5 Replies
  • Christopher Wright
    September 1, 2005 at 5:07 am
    I believe that means it is gay.
  • Mike Kujbida
    September 1, 2005 at 9:57 am
    You’re using Vegas 6, right?
    It means that the event has become ungrouped (audio no longer synced to video).
    Right-click the audio or video event and select “Synchronize – By Moving”.
    Mike
  • Edward Troxel
    September 1, 2005 at 1:23 pm
    It simply means that your audio and video are no longer in sync. It will also tell you the amount it is off sync. You can right-click either event, choose “Synchronize”, and then pick either “By Moving” or “By Slipping”. By Moving will move the event back into sync. By Slipping will leave the event in the same place but will “slip” the section shown so that it is in sync.
    Edward Troxel
    JETDV Scripts
  • Michael Hurwicz
    September 1, 2005 at 4:01 pm
    Yes, Vegas 6. Thanks, Mike and jeditdv!
  • Sergio
    September 5, 2005 at 2:18 am
    How come that if you do a video only insert edit, it thinks it’s out od sync
    and gives you a pink clip with red numbers indicating hoe much you’re out
    of sync. Can you override this, when you make video only edits?
