Activity Forums Adobe Premiere Pro When changing position values of clip with slider it feels unresponsive.
  • When changing position values of clip with slider it feels unresponsive.
    Posted by Jonathon Dzindzio on July 12, 2013 at 12:05 am
    It’s almost as if the preview image of the clip is slipping on ice. I realize this is a strange issue and haven’t found anything during my searches for similar problems. I don’t quite know how to explain it. It only takes place when sliding the values for either the position or the anchor point.
    For example if I slide the value from 0 to 1000 back to zero it will be over a second or two after I’ve stopped moving the mouse that the clip is back to it’s position at 0. But it isn’t just large values. If I slowly move from 0 to 100 it will be fine at first and then start tripping up. If a video of this happening is required I will record my screen for you guys.
    My video drivers are updated.
    Jonathon Dzindzio replied 12 years, 10 months ago 2 Members · 2 Replies
  • Greg Leslie
    July 12, 2013 at 2:25 am
    Which version of PP are you using? Are you using a mouse or tablet? CS6 has a lot of issues (like the ones you’re reporting) with Wacom tablets, don’t know if they’ve been fixed with CC.
  • Jonathon Dzindzio
    July 12, 2013 at 6:06 am
    I’m using CS6, not CC. I’m also using a mouse/keyboard. I’ve tried using another mouse as well and the problem persists. It’s more of a nuisance though as it doesn’t interfere with the finished product.
