Activity › Forums › Adobe After Effects › when AE finishes rendering, video turns black
  • when AE finishes rendering, video turns black
    Posted by Jakob Schlötter on December 28, 2010 at 6:46 pm
    Hello,
    I have a weird problem with rendering.
    – firstly i rendered the video in h.264.
    – the preview in after effects looked perfectly
    – i stopped rendering, and watched the rendered file in quicktime. looked perfect.
    – i continued rendering until after effects finished rendering.
    – i opened the file with vlc & quicktime. it was completely black, audio worked normaly.
    – here are my settings:
    – then i tried the same with quicktime/jpeg-format, with the equal outcomst:
    here the properties of my used footage (it’s shot with a D90 and directly from camera):
    I reviewed my render-history and i saw that the files were only viewable, when i aborted rendering!!!
    weird!
    I could abort shortly before the movie finishes, but that’s a really stupid solution.
    what is happening here?
    when i searched the forum, i didn’t find a proper solution.
    any ideas?
    greetings,
    jakob
    ps: sorry for the german images, but i think translating is not necessary
    Amit Zinman replied 15 years, 9 months ago 2 Members · 5 Replies
  • Amit Zinman
    December 28, 2010 at 9:26 pm
    Did you try updating your quicktime version and maybe a nice restart?
  • Jakob Schlötter
    December 29, 2010 at 9:14 am
    well, i have the newest quicktime version installed (7.6.4) and i restarted several times.
    now i try to render the movie piece for piece uncompressed, and it seems working.
    though it’s not really a nice solution, because i’m running slowly out of discspace 😉
  • Jakob Schlötter
    December 29, 2010 at 8:40 pm
    I read your stock answer already.
    i hoped that i can avoid this.
    also it’s weird, because if i avoid rendering, the file is okay.
    Also, the problem only occurs when i render a composition containing other compositions (I found that out just right now).
    I will try converting the footage, though it doesn’t really make sense to me.
    If it works, I will be confused but happy anyway. Yes, okay, i will try it. Allright.
  • Jakob Schlötter
    December 29, 2010 at 8:55 pm
    haha, okay, so… seems like i need an update… thanks for your patience!
  • Amit Zinman
    December 29, 2010 at 9:33 pm
    Try rendering to qt jpeg or simply to mpeg-2 (which newer versions of Adobe really like, FCP, less so)
