Activity › Forums › Apple Final Cut Pro Legacy › Wheel of death is relentless, even after full software re-install
Jason Porthouse replied 17 years, 2 months ago 7 Members · 14 Replies
Rafael Amador
June 12, 2009 at 4:58 pm[Ryan Kavanagh] “I thought re-installing all my software would do the trick, it didn’t”
After an installing from scratches of MacOSX, QT and FS2, you will find that you have like a “35% of Items out of Order” if you run Diskwarrior. A real mess.
I would start by optimizing the system.
rafael -
Walter Biscardi
June 12, 2009 at 5:41 pm[Ron Craig] “Have you confirmed that all the data you are working with is good? I’ve had something as simple as a corrupted Photoshop file on the timeline cause repeated crashes like this.”
Actually that’s a very good call. One bad piece of media will cause FCP to fail. One thing I’ve done in the past is to Open the project, if FCP opens fine great. Then step through my timeline shot by shot until it crashes. Then delete that piece of media from the array and re-open the project.
Very good idea there and I completely forgot about that suggestion.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Ryan Kavanagh
June 15, 2009 at 4:15 pmJason,
I believe you are the winner. My ram was configured this way, Riser A: (2x 512mb)+(2x2gb), Riser B: (2x2gb)
So I changed it around to Riser A (4x2gb), Riser B (2x512mb)I’ve been working on it for about 8 or 9 hours since then and I haven’t had one crash. I’ve gotten the wheel of death, but it rights itself and fcp doesn’t crash. So I think Jason may have solved my problem.
Ryan -
Jason Porthouse
June 16, 2009 at 3:20 pmRyan,
Try 2 x 2 gig on each riser, forget about the 512s. You’ll be in stable FCP heaven I reckon.
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
