Activity Forums Adobe After Effects What’s wrong with this text?
  • Antoni Jones
    August 26, 2007 at 8:15 pm
    It is possible your rendering settings bitrate/quality settings are too low?, have you tried rendering this out as an un-compressed avi to see if that is what it could be?.
  • Unit_9
    August 26, 2007 at 9:29 pm
    You’re absolutely right – if I remove all compression, it displays fine, but then it also increases from a 5 meg file to a 1gig file.
    It seems to only do this on the bright red elements, too – and be fine with all the others.
  • Kevin Camp
    August 27, 2007 at 1:55 pm
    bright reds can be problematic in video… what is your destination for this piece… web/computer or video?
    if it is video, you have two choices… you can make a broadcast safe color level adjustment in ae by creating an adjustmnet layer at the top of your comp, then add levels and set the black output to 16 and the white output to 235. or if you are taking the piece into an nle, you can import the file as rgb and have the nle convert it to yuv color space. if you do the latter, you will need to work witha codec that gives you better color, like losseless or perhaps a png image sequence, to maintain the color as well as possible.
    if you are outputing for web/computer dispay, then you may want to work again with a better codec as mentioned above, and use a compression tool, like sorenson squeeze, to create the compressed file. compression software will almost always give you better quality and smaller files than just rendering out of ae. they have the advantage of being able to look at all the frames and base compression on the whole piece rather than frame by frame as each gets rendered.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
