Activity › Forums › Adobe After Effects Expressions › What’s wrong with this syntax?
  • What’s wrong with this syntax?
    Posted by Sean Jenkinson on July 6, 2020 at 8:59 am
    I’m following a tutorial in ‘The Power of Expressions’ about optimisation in expressions and I created the following three lines (as directed by the text in the book):
    var Variable1 = 10;
    let Variable2 = 10;
    const Variable3 = 10;
    After Effects has disabled this expression because of a syntax error on line 2, which it claims is missing an expected ‘;’. I’ve checked and rechecked the text in the book but I can’t see a difference.
    What am I not understanding about this?
    I’m using AE CC2020.
    Many thanks.
    Sean Jenkinson replied 6 years, 2 months ago 2 Members · 2 Replies
  • Scott Mcgee
    July 7, 2020 at 7:58 am
    Sounds like you are either using an old version of after effects or haven’t turned off Legacy in your expression settings in project settings.
  • Sean Jenkinson
    July 7, 2020 at 8:41 am
    That’s solved it. Many thanks.
    SJ.
