Activity › Forums › Adobe After Effects Expressions › What’s wrong with my script to enable layer styles?
  • What’s wrong with my script to enable layer styles?
    Posted by Xinlai Ni on September 15, 2009 at 6:10 pm
    Hi cows:
    I have a simple script to add a comp to a project, add a layer to the comp, then
    I attempted to add the “Inner Glow” layer style to the layer. But it doesn’t work –
    by doesn’t work I mean when you twirl down the layer properties, no layer styles
    were ever created.
    Basically what I wanted to do is to automate the menu action
    Layers > Layer Styles > Inner Glow.
    I opened the extended toolkit and watched the var values, the layerStyles variable
    has ‘enabled’ set to true, but its ‘selected’ is set to false, however I can’t
    do layerStyles.selected = true because
    “Cannot set selecred with this property because the property or a parent property
    is hidden”.
    Any help will be appreciated.
    app.beginUndoGroup(“Test”);
    var proj = app.project;
    var projItems = proj.items;
    var comp = projItems.addComp(“foo”, 200, 200, 1, 5, 30);
    var layer1 = comp.layers.addSolid([0.5, 0, 0], “solid”, 200, 200, 1);
    var layerStyles = layer1.property(“Layer Styles”);
    var innerGlow = layerStyles.property(“Inner Glow”);
    alert(innerGlow.enabled);
    app.endUndoGroup();
    Lloyd Alvarez replied 16 years, 8 months ago 3 Members · 3 Replies
  • Lloyd Alvarez
    November 2, 2009 at 11:48 pm
    You need to add the property first using the PropertyGroup addProperty() method
    -Lloyd
    app.project.item(index).layer(index).propertyGroupSpec.addProperty(name)
    https://aescripts.com
  • Tim Andrews
    January 17, 2010 at 12:41 pm
    Although Lloyd’s reply is undoubtably correct, I still don’t understand how to implement “propertyGroupSpec.addProperty(name)”.
    I also fail to understand the Scripting Guide’s explanation of PropertyGroup.
    Although I want to enable ‘Glow’ (as the original poster had wanted), I am assuming the same concepts apply to, for example, setting the type of Light (Spot, Ambient etc) after adding a light using “.addLight”.
    I have searched widely for online explanations or scripts, but even terms like “propertyGroupSpec” only lead me back to the scipting guide.
    Can anyone point me to a page? Or provide some demonstration code.
    Many thanks.
  • Lloyd Alvarez
    January 17, 2010 at 2:12 pm
    Hi Tim,
    Unfortunately, in its current implementation, you can’t set a light type through scripting. If you’d like to understand more about scripting I am currently teaching a scripting course. You can find out more about it by going to aescripts
    -Lloyd
