Activity Forums Adobe After Effects What’s wrong with my script to enable layer styles?
  • What’s wrong with my script to enable layer styles?
    Posted by Xinlai Ni on September 16, 2009 at 10:33 pm
    Hi cows:
    I have a simple script to add a comp to a project, add a layer to the comp, then
    I attempted to add the “Inner Glow” layer style to the layer. But it doesn’t work –
    by doesn’t work I mean when you twirl down the layer properties, no layer styles
    were ever created.
    Basically what I wanted to do is to automate the menu action
    Layers > Layer Styles > Inner Glow.
    I opened the extended toolkit and watched the var values, the layerStyles variable
    has ‘enabled’ set to true, but its ‘selected’ is set to false, however I can’t
    do layerStyles.selected = true because
    “Cannot set selecred with this property because the property or a parent property
    is hidden”.
    Any help will be appreciated.
    app.beginUndoGroup(“Test”);
    var proj = app.project;
    var projItems = proj.items;
    var comp = projItems.addComp(“foo”, 200, 200, 1, 5, 30);
    var layer1 = comp.layers.addSolid([0.5, 0, 0], “solid”, 200, 200, 1);
    var layerStyles = layer1.property(“Layer Styles”);
    var innerGlow = layerStyles.property(“Inner Glow”);
    alert(innerGlow.enabled);
    app.endUndoGroup();
    Xinlai Ni replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
