Activity Forums Apple Final Cut Pro Legacy What’s with Compressor?
  • What’s with Compressor?
    Posted by Chris Babbitt on July 17, 2005 at 7:09 pm
    I just completed my first project since the new Compressor update, and it looks like crap. I’ve always been happy with the results from Compressor encodes in the past, and I have changed nothing as far as I do my settings. This latest project was about 1:50, and I used VBR at 5 mbs avg. and 6 mbs maximum bit rate. I exported a Quicktime reference movie and brought that into Compressor for the encode. The transitions look particularly awful, but pans also break up, and scenes with lots of detail flicker. You get the idea. Is there another alternative? Can I go back to version 1, and still keep FCP 5 & DVDSP 4? Will I get better results using DVDSP for the encoding?. How about using CBR instaed?
    Gabriel Regalbuto replied 21 years, 1 month ago 4 Members · 6 Replies
  • Jerry Hofmann
    July 17, 2005 at 7:30 pm
    Did you set the motion estimation to best? If not, try that…
    Jerry
  • Chris Babbitt
    July 17, 2005 at 9:30 pm
    Yes. That’s the default. I just tried CBR, and it looks ok, at least in the viewer. I won’t know for sure until I look at it on NTSC. But, what’s wrong with VBR? Is it just me?
  • John Fishback
    July 17, 2005 at 10:37 pm
    Check your field dominance. The wrong setting can produce effects like you’re seeing. I’m still using Compressor 1.2.1, but I seem to remember that I had flickering until I changed the encoder setting to lower instead of automatically detect. For some reason it didn’t pick the correct setting on auto. I’m not in front of my computer, but I think those were the choices.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Dual Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
  • Chris Babbitt
    July 18, 2005 at 2:35 am
    Thanks John, but that’s not it.
  • Chris Babbitt
    July 18, 2005 at 2:37 am
    I burned the DVD, and the CBR version looks much better, but still not what I am used to seeing. Still some problems with pans. Dissolves look much better. I’m re-encoding with VBR, just in case it was some kind of fluke.
  • Gabriel Regalbuto
    July 18, 2005 at 4:14 pm
    I was having exactly the same problem. Changing to “bottom field” from auto cleaned it right up.
