Activity Forums Apple Final Cut Pro Legacy Whats with all the rendering?
  • Whats with all the rendering?
    Posted by Robert Douglas on October 18, 2005 at 2:45 am
    When I downconvert uncompressed 4:2:2 23.98 HD to NTSC 23.98 to make the file size manageable for offline I cannot playback the footage on the FCP timeline without rendering. When I playback uncompressed HD 23.98 with the presets set to 1080 23.98 no rendering is needed. I have tried setting the sequence, playback, and capture presets to uncompressed NTSC at 29.97, 23.98 with a variety of codecs. Any ideas on how to improve the workflow. All the rendering is a bummer just to play the clips in realtime. Using FCP 5, Tiger, 2.5 Gig dual G5, 8 gigs of ram, Decklink HD Pro dual link card, Fibre channel to S-Two disk array.
    Robert Douglas
    Jerry Hofmann replied 20 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 18, 2005 at 1:21 pm
    Seems to me that your workflow would be better if you captured the video as NTSC instead of HD… Then no renders would be needed. You can do this with a sony machine’s down convert or with the blackmagic card, no? Then for online, only capture what’s used in the sequence after managing it with the Media Manager.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
