Activity › Forums › Adobe After Effects › What’s up with wiggler in 6.5?
Posted by David Mcsween on August 1, 2005 at 1:27 amI just tried to add the wiggler to a scale attribute in my new AE 6.5, and couldn’t get it to allow me spatial changes it would only allow temporal ones. Is it broken? Is there a simple step I’m missing, I thought that scale was purely spatial anyway.
Cheers
DavidJonathan Alexander replied 21 years, 1 month ago 5 Members · 7 Replies -
John Dickinson
August 1, 2005 at 2:09 amIt works fine for me (AE 6.5 on MacOSX.3.8). Position is both spatial (motion path) and temporal (timeline).
JD
John Dickinson
Motionworks
https://www.motionworks.com.au -
Adam Christl
August 8, 2005 at 3:44 pmI’m having a similar problem. the wiggler is just not working on spatial data. Tried it on null objects, different layers, even updated to 6.5.1, but doesn’t work. the weird thing is it has worked a couple of times and then just won’t. So I’ve ended up cutting and pasting the data to different layers, but this obviously isn’t a solution.
The only thing I’ve updated recently (prior to trying the ae fix) was QT 7.anyone else having issues?
(G5 dual 2gig, 2.5gig ram, OS 10.3.9)
Jonathan Alexander
August 8, 2005 at 10:16 pmWas just having this problem myself. I went searching the posts here to see if anyone else was. So yeah, what do we do about this? Anyone know of any solutions? I like using the wiggler and I know that you can do similar things with a wiggle expression, but I have yet to hear of a way to set a wiggle expression where I can constrain it to just one dimension of my layer’s scale, instead of all dimensions independently. Thats one thing I like about the wiggler. I can have it randomly scale up and down the Y value of a layer’s scale. I don’t know if you can do that with a wiggle expression. Anyways, I hope that there is a fix to this problem soon.
–Jon -
Jonathan Alexander
August 9, 2005 at 5:21 pmThanks Steve! Now, can you explain what the expression is saying exactly? I’m not sure how to then change it so that it is constrained to the X scale. Thanks so much!
–Jonathan
Steve Roberts
August 9, 2005 at 7:22 pmThis expression changes nothing:
[scale[0], scale[1]]
… it just says “change nothing: make the scale behave as you’ve manually set it via keyframes”, but if you imagine it as a starting point, you’re on your way.Here’s the one from my last post:
[scale[0], wiggle(15,50)[1]]It’s saying “the X scale will behave as you’ve set it (keyframes or whatever) but the Y scale will wiggle over a range of 50% 15 times a second”.
The first variable is frequency (15), the second is amplitude(50).
xScale is scale[0].
yScale is scale[1].
zScale is scale[2].
Don’t forget to enclose the whole thing in brackets.Therefore, the X wiggle would be:
[wiggle(15,50)[0], scale[1]]There are other, more elegant ways to write the expression, but this one works for now.
Check out “expressing your wiggle” on the Adobe Studio. It’s not really a tutorial, but examples of wiggle expressions.HTH
Steve -
Jonathan Alexander
August 9, 2005 at 8:40 pmThanks so much! I’ve been wondering how to do this for so long! I appreciate your help!
