Activity › Forums › Adobe Premiere Pro › What’s up with the Audio
Posted by Wasteland on July 26, 2005 at 5:23 amI have been reading the posts for a while now and there seem to be a lot of problems with previewing audio. Now I am having the same problem (premiere 1.5 on a PC)any onw know of a patch or fix?
Scott replied 21 years, 2 months ago 3 Members · 3 Replies -
Steven L. gotz
July 26, 2005 at 5:32 amWhich problem? People leave their cameras attached and forget to set the audio to play on the audio hardware instead of the DV Hardware. But I don’t know of any bugs.
Steven
Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Wasteland
July 26, 2005 at 6:30 pmI have my project built in the timline, when I press enter it renders and starts to play but with no audio. But if i scrub through the timeline you can hear the audio. it just wont play
Scott
July 26, 2005 at 8:23 pmWhen your scrubbing Premiere is using your Sound card in the PC for audio. During playback it is sending the audio through the DV port. In the upper right corner of the preview window there is a little circle with a right pointing arrow. Click on that and select “Playback Settings”. In the drop down menu select “Play Audio on Audio Hardware”. This will tell Premiere to route the playback audio to the computers sound card.
If this does not solve it something else is going on. Let us know.
Scott
