Activity Forums VEGAS Pro What’s this video format and what codec do I need?
  • What’s this video format and what codec do I need?
    Posted by Nick Bucker on January 5, 2012 at 4:07 pm
    I’m new to Vegas. I have a footage that I am trying to import into Vegas but I couldn’t quite figure out what the format of the video is.
    Below I’m pasting the info from MediaInfo and MPEG Streamclip respectively.
    Could you help me figure out the format and what codec I need to install to import this footage in Vegas timeline? and how can I fix non-square pixel aspect ratio?
    Many Thanks,
    Nick.
    Here’s what MediaInfo says about it:
    Format : QuickTime
    Format/Info : Original Apple specifications
    File size : 7.77 GiB
    Duration : 45mn 17s
    Overall bit rate : 24.5 Mbps
    Encoded date : UTC 2011-11-09 00:11:42
    Tagged date : UTC 2011-11-09 00:57:02
    Writing library : Apple QuickTime
    Original source medium : 001
    Media/UUID : AC8168FA-BD8D-4F42-90B4-D565C1049291
    Video
    Format : DV
    Codec ID : dvc
    Duration : 45mn 17s
    Bit rate mode : Constant
    Bit rate : 24.4 Mbps
    Width : 704 pixels
    Original width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.961 fps
    Original frame rate : 29.970 fps
    Minimum frame rate : 0.590 fps
    Maximum frame rate : 23.976 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:1:1
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Bottom Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 3.016
    Stream size : 7.28 GiB (94%)
    Encoding settings : wb mode= / white balance= / fcm=auto focus
    Language : English
    Encoded date : UTC 2011-11-09 00:57:02
    Material_Duration : 2718014
    Material_StreamSize : 7815240000
    Material_FrameCount : 65127
    Here’s what MPEG Streamclip info:
    Video Tracks:
    DV/DVCPRO – NTSC, 720 x 480, 16:9, 23.975999999999999 fps, 23.00 Mbps
    Audio Tracks:
    16-bit Little Endian mono, 48 kHz, 768 kbps
    Nick Bucker replied 14 years, 7 months ago 2 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    January 5, 2012 at 7:32 pm
    As MediaInfo said, the codec is DVCPRO which Vegas doesn’t natively support.
    You can download the Matrox VFW Software Codecs which include DVCPRO from https://www.matrox.com/video/en/support/windows/vfw_software_codecs/downloads/softwares/version1.0/.
    Install this and you should be OK.
    Be sure to set a Restore point before installation just in case something goes wrong.
  • Nick Bucker
    January 6, 2012 at 12:20 am
    Thanks Mike. I just received some details about the footage:
    Canon xh-a1
    format – ntsc 23.97 f/s
    advance pull down 2:3:3:2
    DVCPRO is Panasonic format as far as I know. Do you think it’s wrong detection or could Canon possibly be using this format? It’s kind of confusing.
  • Mike Kujbida
    January 6, 2012 at 2:27 am
    Nick, in that case, forget about downloading the Matrox codec as that camera shoots DV or HDV which Vegas should recognize.
    I seem to recall from reading here and elsewhere that some users have experienced problems with footage from that camera so a search on it on this and other Vegas forums would be your best bet.
  • Nick Bucker
    January 6, 2012 at 6:13 am
    Hi Mike, I already installed Matrox codecs but they didn’t work. Then I installed latest QT Lite and now it plays back in Vegas. However pixel aspect ratio is not fixed. What I view is 702×480. I tried different project properties with no help. How can I fix it?
    Thanks.
  • Mike Kujbida
    January 6, 2012 at 2:27 pm
    Nick, what puzzles me is that MediaInfo said that the the width was 704 pixels but the original width was 720 pixels.
    Did someone else do the capture of this footage?
    Do you know what software they used?
    Have you tried setting your project properties to DV widescreen mode (1.2121) and then using Pan/Crop to “match output aspect”?
  • Nick Bucker
    January 6, 2012 at 6:41 pm
    It’s quite bizarre. Vegas detects it as PAL. When I change clip’s property to PAL and set “maintain aspect ratio” in pan&crop to NO, then dimensions looks right. Is it ok to continue with editing as long as it looks right, no matter how I got it working?
    This way, although the dimensions look right, image looks very flat, very dull, as if I’m viewing it behind a brown screen door. I’m sure that camera is capable of better picture. I am wondering if color space is interpreted correctly?
    I don’t know the videographer who shot this. He is a friend of a friend of a …, so it is not easy to get more info.
  • Mike Kujbida
    January 6, 2012 at 7:29 pm
    ” Is it ok to continue with editing as long as it looks right, no matter how I got it working?”
    Based on what you’ve told me so far, I say no.
    We need to figure out what’s wrong and how to fix it.
    “This way, although the dimensions look right, image looks very flat, very dull, as if I’m viewing it behind a brown screen door”
    PAL is a completely different color system (as well as frame size and rate) than NTSC so this doesn’t surprise me.
    Can you post a small clip (30 sec. or so) onto DropBox, send me the link and I’ll take a look at it on my machine to see if I can figure out what’s going on.
  • Nick Bucker
    January 8, 2012 at 5:18 am
    I’ll prepare the clip tomorrow. Thanks for the kind offer.
