Activity › Forums › Adobe After Effects › What’s this effect ? (Jiggy animation)
Posted by Alp Tekyildiz on March 11, 2009 at 3:37 pmHi all.
can you look at this video and tell me what effect this is and how to recreate it ? I’m talking about the line’s shaking and transpary changes. I’m not talking about the line being drawn, just its shakyness.
Thanks a lot
Jeremy Allen replied 17 years, 6 months ago 4 Members · 6 Replies -
Eric Sanderson
March 11, 2009 at 4:46 pmTheres an effect in AE called scribble that can give you that look, looks like there could also be some posterized time applied to it (or its just playing back chunky because im rendering from 2 programs on my computer as im watching it)
Kevin Camp
March 11, 2009 at 5:27 pmalso a wiggle expression on the line layer’s position property would give a natural ‘camera shake’ like movement.
enable expressions for a layer’s position (select the position property, the choose animation>add expression). type an expression like this:
wiggle(2,5)
this will ‘wiggle’ the layer by changing the position value ‘2’ times per second at an amount of ‘5’ pixels. you can create smoother or more shaky results by modifying the values in the ().
for more on the wiggle expression (and expressions in general) look up expressions in the ae help file…
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Alp Tekyildiz
March 11, 2009 at 7:26 pmThanks a lot, the Wiggle expression was what I needed. Just another question though, what I’m animation are the lines of country borders on a map. The lines are all one layer so when I animate their position, they all move together. I was wondering if there was a distortion effect I could use that would reproduce the video’s shaky feel without looking like all the borders are one object.
Thanks a bunch.
Jeremy Allen
March 12, 2009 at 12:00 amSomebody suggested Turbulent Displacement for a similar effect in another thread.. Maybe give that a try
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.2AE CS3
Alp Tekyildiz
March 12, 2009 at 9:14 amThe turbulent displacement works pretty well actually. Thanks for that.
Jeremy Allen
March 12, 2009 at 6:20 pmNo problem, glad i could help!
