Activity Forums Apple Final Cut Pro Legacy What’s the latest safe QT Pro Update
  • What’s the latest safe QT Pro Update
    Posted by Chris Gorman on February 14, 2009 at 5:32 am
    FCP Studio crashed and the only thing I can access on my hd is the much earlier 5.0.4 version and related versions of the other apps., and the earlier 7.1.3 QT
    (Strange that search shows the correct current versions sitting in my apps folder, but they can’t be accessed in any way, only the earlier version that are visible and accessible in the apps folder when I go directly into that folder, not through search.)
    So, I’m getting ready to re-install fcp studio 2, fcp 6 from my disks….but it tells me I first need to update QT to at least 7.1.6
    I wish I could remember what version I was using before the crash. I’m hesitant to do the online software update which only lists QT 7.6, I just want to go with what has been tried and tested by fcp users, and will update only as far as that version.
    Opinions? experiences? on the safest non problem version of QT Pro to use with fcp studio?
    Rafael Amador replied 17 years, 7 months ago 3 Members · 11 Replies
  • 11 Replies
  • Rafael Amador
    February 14, 2009 at 6:31 am
    Hi Chris,
    You mean that you have installed few FC versions in the same System?
    Rafael
    http://www.nagavideo.com
  • Chris Gorman
    February 14, 2009 at 8:15 am
    Correction, I later noticed that my G5 had booted onto an older HD that had fcp 5 on it. I did not select it as the startup disk, so don’t know how that happened.
    When I set the startup disk to the correct hd, it booted ok and I actually worked a few minutes in fcp before the strange behavior started again….suddenly a bunch of text came across my screen right over my fcp interface, saying System Failure, a bunch of numbers and ….kernal version.
    Now, I just booted onto an older external hd, so I actually have control now to do something.
    BTW, before it got this bad, the first indication was an error code 41 that appeared when i was working in fcp6. All downhill from there.
    If I can re-install fcpstudio2 onto my main hd while booted on my external, at least I can proceed. Now, when the time comes, what version of QT is now best with fcp6 6.0.2 ?
  • Rafael Amador
    February 14, 2009 at 10:01 am
    Hi Chris,
    I don’t think is possible to install two versions at the same time.
    Here you can find a list with the FC-QT matching (?) versions:
    https://visualnary.com/tag/final-cut-studio
    i really don’t remember which I used.
    BTW, do you really need to work with FC 6.0.2?
    Rafael
  • Paul Dickin
    February 14, 2009 at 10:28 am
    Hi
    All the older versions of QT that Apple regard as stable are still available on these pages:
    https://support.apple.com/downloads/
    Just page back to 2007 or earlier for old versions.
    This link to Rafa’s QT version page is more up to date:
    https://www.digitalrebellion.net/blog/posts/recommended_quicktime_and_mac_os_configurations_for_final_cut_pro.html
  • Chris Gorman
    February 14, 2009 at 6:33 pm
    Thank you. This is exactly what I was looking for : )
  • Chris Gorman
    February 14, 2009 at 6:42 pm
    When you ask “do you really need to work in fcp 6.0.2?” are you suggesting I use a more recent update or something older?
    I’ve been working with 6.0.2 for so long that I don’t remember what advantages it has over the previous version or what it might lack compared to newer version.
    I definitely don’t want to go backward, but will go as far forward as is safe.
    I work mainly with ProRes 8bit 422 from hdv footage.I also use h.264, so might want to update to the latest QT later for better h.264, not now, but after it gets past the initial fixes that are inevitable.
  • Rafael Amador
    February 15, 2009 at 1:47 am
    Hi Chris,
    [chris gorman] “‘ve been working with 6.0.2 for so long that I don’t remember what advantages it has over the previous version or what it might lack compared to newer version.”
    And I stopped working with 6.0.2 so long ago that I can not remember the full lists of bugs:-)
    I have installed the last versions of FCS and QT in both, a G5 PPC and a MBP Intel and everything works fine.
    Rafael
  • Chris Gorman
    February 15, 2009 at 3:24 am
    I read somewhere in these forums that there’s been a few glitches using QT 7.6 with OSX.4.11
    Until I can upgrade my Photoshop CS, I have to stay with 10.4.11
    Are you using QT 7.6 with Leopard?
  • Rafael Amador
    February 15, 2009 at 3:55 am
    Yes Chris. I have leopard installed in both computers.
    rafael
  • Chris Gorman
    February 18, 2009 at 11:44 pm
    Is this current info on rafa’s link for qt version recommendations?
    I will have to look for fcp 6.0.2 or 6.0.3 on a third party site because apple has replaced those choices with fcp 6.0.5 which requires qt 7.5.5 and either osx.4.11 or osx.5.5 (i’m using osx.4.11).
    PowerPC G5 DP2.3, 4GB DDR SDRAM, ATI X800XT, OSX.4.11, FCStudio2, Sonnet 5 Bay SATA (RAID or JBOD as needed), ACD 23″ & Sony NTSC Monitor via Matrox v.1
    Sony ZIU hdv, edited w.ProRes
