Activity Forums Apple Final Cut Pro Legacy Whats the bitrate limit for H.264 codec?
  • Whats the bitrate limit for H.264 codec?
    Posted by Pengchon Vann on June 8, 2010 at 7:11 pm
    I notice when I try to set the bitrate as high as possible, the max comes up to 144,000.
    Now my problem is, I’m not sure if this is the max or I’m limited.
    I think my h.264 codec bitrate setting is damage, and I have no ways to fix it.
    Here is what I did.
    I made several test.
    For a 720×480 5minute video using h.264 codec.
    set bitrate 500 = 93,024kb
    set bitrate 1000 = 93,024kb
    set bitrate 5000 = 93,024kb
    set bitrate 20,000 = 93,024kb
    Now after setting the bitrate to different rates, why does my files comes out to be the same size?
    Dane Henry replied 16 years, 3 months ago 4 Members · 3 Replies
  • Alan Okey
    June 8, 2010 at 8:32 pm
    Try posting your question in the Compression Techniques forum for a faster response.
  • Rob Grauert
    June 8, 2010 at 9:36 pm
    What are you trying to do, export the best quality H.264 file?
    For that, I just move the Quality slider to “Best.”
    Next, if you hold down the Option key and hover your cursor over the Quality slider, you’ll notice it chances to Temporal. Move that to “Best” too.
    maybe that will result in a higher bitrate?
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Dane Henry
    June 9, 2010 at 5:21 pm
    Are you using compressor? If so, with a 720×480 you shouldn’t really need to go any higher than 6000-8000kbps. Click the video settings tab & enter what you want for kbps. Test it out see what you think is acceptable. I find for SD that 6000-8000kbps is “visually” lossless
    hope this helps.
    -Dane Henry
    DeepRootsMedia.com
