Activity Forums Square Box CatDV What’s the Best XAVC S / AVCHD Workflow?
  • What’s the Best XAVC S / AVCHD Workflow?
    Posted by Will Luker on May 23, 2018 at 10:39 pm
    We are ready to ingest a bunch of footage into CatDV and I want to see if there’s a better way to tackle the XAVC / AVCHD cards.
    Right now, I’m copying the entire contents of the card at ingest, and then generating a low-res proxy for editing and a remux (re-wrap) on MTS files.
    The challenges I’m facing:
  • Relinking proxy to high-res in premiere is a challenge because the clips start with C0001 etc
  • The format is finicky, and complains if it’s missing any files
  • I’m thinking I will run an ingest action, move all the JPGS, and then just move the .mp4s (XAVC) or remux the MTS files and forget about the rest of the card contents.
    Will this approach work? What am I missing? Is there a better way?
Will Luker replied 8 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
