Activity Forums Adobe After Effects Whats the best way to have a kind of faded delay on a solid moving?
  • Whats the best way to have a kind of faded delay on a solid moving?
    Posted by Daniel Haskett on May 11, 2007 at 11:51 am
    Hi there,
    Basically, if you look here https://www.motionscript.com/mastering-expressions/random-3.html You can see on the left the movies with the dots moving around. What I want to try and do is have them moving around but with multiples of them following behind each progressively more transparent, so there is a kind of tail following behind i spose you could say….does that make sense?
    I know i could do a precomp and keyframe them all and parent them to the main layer, just wondered if there was an easier way 🙂 maybe with expressions or something similar?
    thanks alot!
    dan
    Steve Roberts replied 19 years, 4 months ago 2 Members · 1 Reply
  • Steve Roberts
    May 11, 2007 at 12:36 pm
    Drop the comp into a new comp, then apply effect>time>echo to it there?
