Activity Forums Apple Final Cut Pro Legacy What’s the best way in my situation to rip blu-ray to maintain quality?
  • What’s the best way in my situation to rip blu-ray to maintain quality?
    Posted by Nikolai Metin on April 25, 2012 at 3:36 pm
    I have a blu-ray copy of an event that needs to be reedited. Just straight cutting it down, no effects work or color correction.
    What’s the best way to go about ripping it, editing, reexporting back to blu-ray, in order to maintain the most of the original quality?
    Btw, I’m posting it in fcp 7 forum, but I’m fine working in premiere/avid/fcp x, if someone thinks there’s a better solution there.
    Should I repost this in another category on creativecow?
    Juan Salvo replied 14 years, 4 months ago 2 Members · 3 Replies
  • Juan Salvo
    April 25, 2012 at 4:36 pm
    If you can copy the m2ts files of the disc, you can work with these natively in premiere. Would say that would be best.
    online editor | colorist | VFX | BD author
    https://JuanSalvo.com
  • Nikolai Metin
    April 26, 2012 at 2:29 pm
    Thanks a lot! What does that imply in terms of sequence settings and at the end, export settings? In premiere, I only worked with dslr and red stuff. No experience with m2ts.
    “I cut, I disco…”
  • Juan Salvo
    April 26, 2012 at 6:40 pm
    Sequence setting: You need to match your media, and export will require recompression. If you want to go back to bluray you can dynamic link straight to encore.
