Activity Forums Compression Techniques What’s the best solution for an MPEG2 encoding from a ref file?
  • What’s the best solution for an MPEG2 encoding from a ref file?
    Posted by Alexander Gao on March 20, 2006 at 10:42 pm
    Out of fcp, I have exported a reference file. Would you suggest that Squeeze, Compressor, or Cleaner will give me the best MPEG2 compression?
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
    Claireystew replied 20 years, 5 months ago 3 Members · 2 Replies
  • Ed Dooley
    March 21, 2006 at 4:11 pm
    I can answer part of the question, DON’T USE CLEANER! It’s not a good MPEG-2 compressor.
    Ed
  • Claireystew
    April 3, 2006 at 2:03 am
    I haven’t used Squeeze in a while, but between Cleaner and Compressor, Compressor was by far the better result, as long as you can live with the limitations it imposes on the MPEG2 file.
