Activity › Forums › Apple Final Cut Pro Legacy › Whats the best Firewire 800 card
  • Whats the best Firewire 800 card
    Posted by Vladislav on February 2, 2006 at 11:38 pm
    I know for the best results with your G-Raid firewire 800 drives (or any FW drives for that matter) one should have it on the separate bus, like buy a separate card for it, what’s the card you guys had good results with.
    we need two, one for Mac G5 2.5Ghs, and one for G5 2.7 Ghz
    Thanks in advance
    Vlad
    Joslyn replied 20 years, 8 months ago 5 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    February 3, 2006 at 1:03 am
    I just have the two drives daisy-chained to the main FW 800 port. No problems so far.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Don Greening
    February 3, 2006 at 5:14 am
    I’ve had good results with this one:
    https://www.lacie.com/products/product.htm?pid=10173
    – Don
  • Joslyn
    February 3, 2006 at 2:27 pm
    just picked up a g-raid. i have a firewire 800 port on my powerbook and will never use the firewire 400 port simutaneously. when people say slow down will occur because the ports are on the same bus, do the mean when using the 400 and 800 ports at the same time or since the 800 and 400 are on the same bus the 800 will slow down anyway? thanks.
  • Shane Ross
    February 3, 2006 at 3:16 pm
    If a FW400 device and FW800 are on the same bus, then the FW800 slows down to FW400.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Joslyn
    February 3, 2006 at 6:14 pm
    so i’ll need a firewire 800 pcmcia card anyway since the powerbook’s firewire 800 port only gives me 400mbps? do i understand that correctly? i thought it was only an issue w/ the g5’s? thanks…
  • Shane Ross
    February 3, 2006 at 10:19 pm
    Sorry, don’t own a powerbook, so I cannot say for sure.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Debe
    February 4, 2006 at 3:46 pm
    If you have a FW 400 device connected to the PB, then any FW 800 device will slow down to FW 400. FW 800 alone should give you FW 800 speeds.
    Getting a PCMCIA card can give you 2 busses of FW 800 speed, providing the devices attached run at FW 800. Attaching a deck or camera will drop either one down to the equivalent of FW 200, I believe.
    debe
  • Joslyn
    February 5, 2006 at 5:04 am
    thanks for the clear up debe. you just saved me $80. =)
