Activity › Forums › AJA Video Systems › What’s happened?
What’s happened?
Posted by Sean Davison on October 24, 2008 at 5:46 pmAfter months of Rock solid operation my Kona 3 has suddenly become very unreliable laying back to tape – it drifts around by a frame. I’m laying back to an a500p Digi – Ref is set to input video I’m using the latest drivers (but not the latest ver of leopard 10.5.4 and not the latest quicktime 7.5) It sounds like the decks having trouble getting a stable signal. Its taken me a day to fix an audio dropout – it reminds me of Cinewave days!!!!!
Gary Adcock replied 17 years, 11 months ago 4 Members · 14 Replies -
Jeremy Garchow
October 24, 2008 at 7:51 pmIs your Dbeta machine looped in to the Kona? If so try pulling the ouput of the Dbeta (or input in the Kona) and see what happens.
What drivers?
Sean Davison
October 24, 2008 at 7:55 pmThanks Jeremy,
I’ve tried both – even with the digi connected just to the kona op and ref’ing input video it’s still all over the place.
Sean Davison
October 24, 2008 at 8:09 pmi downloaded them today to try to fix this – I should point out that Im down converting a 1080i50 sequence to pal 625 (never tried this before)
Jeremy Garchow
October 24, 2008 at 8:18 pm[Sean Davison] “I should point out that Im down converting a 1080i50 sequence to pal 625 (never tried this before)
“A ha. That’s it. You will lose a frame due to the conversion. You will have adjust accordingly.
Jeremy
Mike Zimbard
October 24, 2008 at 8:42 pmVery interesting. Jeremy can you explain why? I’m trying to understand why a frame would be lost. Aren’t you just going from 1920×1080 @25 fps to 768×576 @25fps? How is this different from an NTSC downconversion @ 29.97? Just curious as to the technical reason.
Mike Zimbard
October 24, 2008 at 9:22 pmAh – ok. Makes a lot more sense. Thanks for the clarification. Is this not the case with an NTSC downconvert or do you have to account for the one frame with any K3 conversion?
Jeremy Garchow
October 24, 2008 at 9:31 pmNot lost, but delayed a frame. Sorry about that confusion. It’s due to processing time.
Mike Zimbard
October 24, 2008 at 10:48 pmIs that acknowledged in the manual? Seems like a big deal and I can’t remember ever hearing that before regarding the hardware down-converts.
