Activity › Forums › Compression Techniques › what’s better than compressor?
  • what’s better than compressor?
    Posted by Alexander Gao on December 31, 2005 at 7:15 am
    Are there any programs that will give me a better MPEG-2 compression than compressor 2?
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
    Rich Rubasch replied 20 years, 9 months ago 4 Members · 6 Replies
  • Ben Waggoner
    December 31, 2005 at 9:29 pm
    It’s the best I’ve tested for Mac.
    The best I’ve tested overall is ProCoder on Windows.
    My Book: https://www.benwaggoner.com/books.htm
    Squeeze and ProCoder tutorials: https://www.classondemand.net/benwaggoner/
    Compression Class at Stanford: https://www.digitalmediaacademy.org/compression.html
  • Charles Simonson
    December 31, 2005 at 11:48 pm
    Compressor 2, BitVice, MainConcept, and Compression Master 3.2 offer very good MPEG-2 encoding on the mac. It is difficult to say that just one encoder is the absolute best there is today, as I have seen different types of sources (interlaced, progressive, DV, film, animation, HDV) come out better between the encoders depending on what source was used.
  • Rich Rubasch
    January 1, 2006 at 12:33 am
    Ben, are you saying Compressor 2 is the best performer on the Mac?
    Really?
    Rich Rubasch
    Tilt Media Inc.
  • Ben Waggoner
    January 1, 2006 at 1:38 am
    Best overall.
    As Charles said, there are special cases where things could vary. For example, Main Concept is the only Mac encoder I’ve tested that correctly does motion search in chroma as well as luma, which can help in some edge cases, like test patterns.
  • Charles Simonson
    January 1, 2006 at 11:08 pm
    I forgot to mention that there are demos available for all of the apps I mentioned. So the easiest thing to do is download the demos and test your source with them and then determine if an upgrade to Compressor 2 is something you need or could benefit from.
    CM3 = http://www.popwire.com
    BitVice = http://www.innobits.com
    MainConcept = http://www.mainconcept.com
  • Rich Rubasch
    January 2, 2006 at 2:17 am
    Honestly, Ben, you are saying that compressor 2 is better overall than Bitvice or Main Concept for MPEG-2 encoding for DVDs? I know most compressor users have gone to a straight CBR encoding because Compressor had a problem with spiking in VBR encodes and I have seen them where a spike would choke a player. If an encoder can’t do VBR then it should be disqualified.
    Compressor 2 does add quite a bit….but for just MPEG-2 FOR DVDs is Compressor still your best choice overall?
    I ask again because I trust you!
    Rich Rubasch
    Tilt Media Inc.
