Activity › Forums › Apple Final Cut Pro Legacy › What’s best way to ingest then Export BETA SP footage for archiving as Quicktimes
  • What’s best way to ingest then Export BETA SP footage for archiving as Quicktimes
    Posted by Rory Keenan on June 24, 2010 at 10:30 pm
    I’m working with a documentary film director.
    He wants about 70 old BETA SP tapes saved as Quicktimes for archiving.
    The footage was originally shot on 16mm film at 24fps.
    It was converted on to BETA SP (NTSC 29.97), Address tack timecode, Key code in User Bit.
    Any Suggestions for a workflow??
    We want to preserve the highest image quality possible.
    We obviously want to save time.
    We are also considering doing this in Avid (I’ll post this on the Avid fourm also)… if somebody has a recomendation between Avid and FCP for this it would be welcome.
    We are using FCP 7 with an AJA ioHD box
    I’m considering Capturing in 10bit Uncompressed
    Do I then need to Export as a different format?…. Or can I just use the Quicktimes that FCP creates from capture?….. Or should I convert them to another format using Compressor??
    I did some test clips I captured in:
    Device Control- AJA ioHD NTSC Sony VTR
    Capture/Input- AJA ioHD 525 29.97 10 bit
    I played these test clips in both FCP and in Quicktime player and the same clip looks different.
    Can anybody explain (did I overlook something basic?)?
    The clip looks fine when played in FCP.
    However when I select the same clip at the finder level and open it in Quicktime player the Aspect ratio is stretched and the image breaks down if a subject moves quickly in the frame (horizontal lines).
    Any Suggestions??
    I’m also having problems getting his FCP system to recognize the BETA deck.
    I’ll write a separate post for that.
    Shane Ross replied 16 years, 3 months ago 4 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    June 24, 2010 at 10:37 pm
    I’d capture as PRORES. That’s a darn good codec. And now Avid MC5 supports that format, so that might be the most universal one. And it has a lower data rate than Uncompressed, so you can fit more on less space.
    As for the QT/FCP discrepancy…that is just the way things are. QT lightens the gamma. In the QT preferences you can set them to FCP COLOR COMPATIBILITY. But that is the LAST PLACE to judge your color and quality.
    Shane
  • Rory Keenan
    June 24, 2010 at 10:52 pm
    The image difference between Quicktime-player & FCP is not a color issue.
    The problem is the Aspect ratio is stretched… it doesn’t look 4:3 in QT…. It’s stretched horizontally.
    The image also breaks up a little (in the form of horizontal lines) if a subject does any quick movements (like hand gestures when he speaks)
    Thanks for the Pro Res suggestion.
    I often use that codec…. but will there be any quality loss if i use ProRes instead of Uncompressed (that’s an important issue to the director)???
    Also would you recomend ProRes for ingest & output… OR Ingest uncompressed then export ProRes… OR could I ingest in ProRes then simply use those QT files that FCP creates in the Capture scratch folder???
  • Shane Ross
    June 24, 2010 at 11:17 pm
    [Rory Keenan] “The problem is the Aspect ratio is stretched… it doesn’t look 4:3 in QT…. It’s stretched horizontally.”
    Yeah, QT doesn’t always play back the proper TV aspect ratio. It will change it. TV aspects and QT aspects are different.
    [Rory Keenan] “The image also breaks up a little (in the form of horizontal lines) if a subject does any quick movements (like hand gestures when he speaks) “
    That is INTERLACING. Looks fine on tape as the format is interlaced, but computer monitors have a tough time playing back interlaced and having it look good. It simply can’t. Progressive is what computer monitors need. But you aren’t archiving for computer monitor playback, you are archiving for…TV playback. Right?
    [Rory Keenan] “I often use that codec…. but will there be any quality loss if i use ProRes instead of Uncompressed (that’s an important issue to the director)??? “
    Yes. ProRes is a compressed format. But it will be minimal loss. BUT, if they want less lossy, and they have the drive space, go for Uncompressed.
    Shane
  • John Christie
    June 24, 2010 at 11:36 pm
    Shane is right, prores is a great codec for archiving. Remind the director that beta sp is also a compressed format. Some people here the word compression and think it’s bad. Every video format in existence has used tricks, analog and digital to reduce the amount of information being recorded.
  • Bouke Vahl
    June 24, 2010 at 11:40 pm
    Since when is a proprietary codec “universal” ????
    (and when i read ‘best’ in a subject header, i don’t feel like responding…)
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Rory Keenan
    June 24, 2010 at 11:45 pm
    Actually these are being archived for Computer monitor playback
    An ethnic studies institute wants the footage.
    They want two main things:
    1) They want to be able to upload low-res versions of the clips on to the internet (so scholars can reference for research)….they will convert the Quicktimes to whatever low res format they need.
    2) They want to be able to sell high quality clips to people who want to use the footage in other documentaries.
    (anyone buying this footage will likely be editing on a Computer monitor in FCP or Avid)
    Either way I think the clips need to look good in Quicktime playback on a computer monitor?
    The aspect ratio can’t be distorted on the Quicktime computer monitor playback.
    (Shane) “Yeah, QT doesn’t always play back the proper TV aspect ratio. It will change it. TV aspects and QT aspects are different. “
    So what formats (for ingest & Output) would you recomend for archiving these as High Quality Quicktimes for playback on a computer monitor???
    (Shane) “That is INTERLACING. Looks fine on tape as the format is interlaced, but computer monitors have a tough time playing back interlaced and having it look good. It simply can’t. Progressive is what computer monitors need. But you aren’t archiving for computer monitor playback, you are archiving for…TV playback. Right?”
    Yes, these need to look good on computer monitor playback.
    Is there a way to capture these as progressive??
    So basically I need these to look good in Quicktime playback on a computer monitor.
    Is there a way to capture in a format that will do that?…. then I can just use the Quicktimes from the Capture-Scratch folder??
    OR do I need to capture… THEN EXPORT or use Compressor to out put Quicktimes in a different format???
  • Rory Keenan
    June 24, 2010 at 11:49 pm
    For you I’ll rename the Subject 🙂
    “What’s a good quality way to ingest then Export BETA SP footage for archiving as Quicktimes??”
    As for the the recomendations on codec… Thank You.
    ProRes is the codec I like to use most, and I think I can convince the director to go with ProRes 422
    BTW What is the difference between ProRes422 & ProRes422 (HQ)
  • Bouke Vahl
    June 24, 2010 at 11:59 pm
    [Rory Keenan] “BTW What is the difference between ProRes422 & ProRes422 (HQ)”
    If you ask a question like this, have you even tried both and looked at the difference or tried to measure it?
    Probably not.
    My advice, step out and let someone with at least a bit of know-how handle this, or get a crash course in basic video technology.
    That will set you back a couple of weeks and a couple of thousands bucks. Look on the bright side, the crappy betadeck you are using costed some 15K back in it’s days. (good ones were about 40K)
    You have no idea about what you are doing, that won’t be good for your client and will backfire at a time.
    Bouke
  • John Christie
    June 25, 2010 at 12:09 am
    If the source material was 16 mm you can use Cinema Tools to remove the pulldown and create 24fps QT files. That will get rid of the interlace issue. Any codec digitizing interlaced source material will have problems playing back on a computer, not just pro res.
  • Shane Ross
    June 25, 2010 at 5:49 am
    [Rory Keenan] “1) They want to be able to upload low-res versions of the clips on to the internet (so scholars can reference for research)….they will convert the Quicktimes to whatever low res format they need.”
    Then compress as H.264…and deinterlace when you do. Compressor has presets for various data rates.
    [Rory Keenan] “2) They want to be able to sell high quality clips to people who want to use the footage in other documentaries.
    (anyone buying this footage will likely be editing on a Computer monitor in FCP or Avid) “
    Photo JPEG is the format that most stock footage companies compress their footage. So you will have to capture it, and then convert it.
    Shane
