Activity Forums Adobe Premiere Pro What’s a quick way to make this edit?
  • What’s a quick way to make this edit?
    Posted by Ralph Zakib on November 25, 2020 at 4:47 am
    I have a video of a sports game
    https://i.imgur.com/nsest9d.png
    I have numbered all the rallies.
    I want to cut out the parts of the video that are in between the rallies.
    But I don’t want it to go straight from one rally to another, because then it jumps too soon for me the viewer to see when a rally ends and when a rally starts. So I want a black screen or simple picture like a picture of a square, in between each rally, that is just there for 2 seconds.
    What’s a quick way of editing it to do that.
    If I do HOME, it will be beginning of first label that is at the start of the clip, then keep doing SHIFT-DOWN, it will go to the end of the first label, SHIFT_DOWN will go to beginning of second label. SHIFT-DOWN again will go to the end of the second label e.t.c. Deselecting the clip with the shortcut ctrl-shift-A doesn’t always work for some reason, so I manually click outside the clip, but anyhow.
    So I can do SHIFT-DOWN, MARK IN(I), SHIFT-DOWN, MARK OUT(O), DESELECT CLIP(ctrl-shift-A), RIPPLE DELETE(shift-delete), I can copy a 1 second image of a square to the clipboard. And do CTRL-SHIFT-V (Paste insert).
    I’m wondering if there is a faster way?
    It’d be good if there way a way to, instead of ripple delete, to do a ripple delete and paste insert image in one go.. And to do SHIFT-DOWN, MARK IN, SHIFT-DOWN, MARK-OUT, DESELECT, RIPPLE DELETE,
    Can I even do that in one go?
    View post on imgur.com
    Ralph Zakib replied 5 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
