What? A maximum “layer style stroke” size?
So I was finally happy with this awesome dazzling piece I made where a series of layers had strokes applied to them which were each set to grow from 0 to a size that fills the screen. The effective look was that each layer was radiating solid colors.
It looked great!…until I started to render. That’s when I realized that my comp view was on half-res, and that as soon as I put it to full, everything was wrong.
It seems that AE when in full res mode will not allow you to make a stroke larger than apx 300. But it looks fine in lower resolutions.
What is with that? How do I make it work or get around it with effects?
