Activity › Forums › DSLR Video › What would I need to do to get the same video quality as this video?
  • Chris Wright
    January 1, 2013 at 11:07 pm
    If I had to guess, best guess would be:
    the dynamic range was 3 f-stops not 10 because they used very soft, diffused lighting and a medium aperture for depth of field, prolly f/5.6. Framerate looks to be 30 fps progressive 1/100 shutter. 5d MarkII 50mm carl zeiss lens. Not much post color correcting. Just white balanced.
  • Steve Crow
    January 2, 2013 at 1:45 am
    Start by using the “Philip Bloom” DSLR camera settings:
    Sharpness and contrast all the down to ZERO
    Saturation down 2 notches to -2
    In editing you can add back in as much sharpness, contrast and saturation as your eye likes, just enough to be soft as in “filmic” but not so much that it appears out of focus.
    The second sample of video that was more similar to yours had what I would call a more contrasty, saturated blacks kind of look (note: your eyes are different from mine and so your results may vary) and often there was only a strong key light and not much of a bounce light on the other side of the face to balanced it out.
    Steve Crow
    Crow Digital Media
    http://www.CrowDigitalMedia.com
  • Sareesh Sudhakaran
    January 2, 2013 at 4:45 pm
    I recommend the 5D Mark III. This might help you with the first part of your question: https://wolfcrow.com/blog/what-is-the-best-dslr-for-video/
    https://www.wolfcrow.com – Workflow information and support for filmmakers, photographers, audiographers and videographers.
  • Rafael Amador
    January 7, 2013 at 12:41 pm
    The camera is just one factor.
    The Canon or PANASONIC will do the job, but you won’t get that without proper lighting a good make up.
    rafael
    http://www.nagavideo.com
