Activity › Forums › DaVinci Resolve › What will you choose?
Posted by Bernard James on November 11, 2011 at 11:48 amHi guys
So next step for me is to definitely find a broadcast monitoring solution. I know it is always the same question!
so i try to make it fast!
The fact is that i have 3 ways for almost the same price!1- new pana bt300U and may be calibration
2- Calibration and a standard Pana pro
3- Fsi 24” but only 24” !!What will you choose?
I will trust you as i can not see by myself one of these solutions before buying itbest regards!
Bernard
Chris Hall replied 14 years, 10 months ago 9 Members · 15 Replies -
Margus Voll
November 11, 2011 at 11:53 amI would go with fsi as primary monitor and pro Panny as client monitor.
Margus
Ola Haldor voll
November 11, 2011 at 12:51 pmWhat he said.
I’d prefer accurate colors rather than size in the first place. Whenever you can afford the extra boxes, cables and a large TV, go for it, but use the FSI as the monitor.
Bernard James
November 11, 2011 at 1:09 pmMany Tks for answering, Ola and Margus!
So 2 points for FSI! -
Charles Haine
November 11, 2011 at 2:04 pmI’ll chip in with a 3rd: we have the FSI as our main monitor, with a 2 year old panny pro plasma set up for client monitoring.
Tony Manolikakis
November 11, 2011 at 2:18 pmWe use the Panny, with a probe and the Davio. A bit costly but there is no LCD monitor that compares IMO. New Panny will be even better.
Tony Manolikakis
Rev13 Films -
Teo Rižnar
November 11, 2011 at 2:50 pmThere is always just a debate between LCD and Plazma displays. Nobody is asking them selfs why the bigest and the best, let’s say it that way, colorist are still working on old CRTs, is the new Sony BVM OLED finally replacing BVM-D line of 32″ and 24″ CRTs, how they were called back in the days digital cinema CRTs?
I had an opportunity to se old BVM and new LCD same ambient same source, it is a big difference!Here is a Sony promo video about it:
https://vimeo.com/28860170Yes, and you can get used CRT for similar price you are spending on LCDs, plazma etc… It is just eBay digging 😉
P.S.: I work on a 24″ JVC LCD (very very bad monitor) and a old 12″ CRT. The CRT is first to look, level out the contrast, than I look on LCD and adjust the colors.
Color grade reel: https://vimeo.com/15480583
Cofounder of https://nuframe.si postproductionSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Margus Voll
November 11, 2011 at 3:00 pmi bet those colorists using crt’s can calibrate them in any second before sessions. old crt’s are like plasmas
in time, fading, moving around a bit depending if it is rainy day etc.in that sense i would not consider crt. and yes they will go out of focus in the end.
Margus
Robert Houllahan
November 11, 2011 at 3:10 pmI like my calibrated Panny 11-UK and will get a 300 series when I can. I generally do not like LCD’s and feel like I would rather deal with the Plasma issues than use a LCD.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
Margus Voll
November 11, 2011 at 3:22 pmI would go with fsi + 300 series.
2 separate types of displays is good for comparing anyway
Margus
Teo Rižnar
November 11, 2011 at 5:24 pmMargus I agree! This is old equipment and we all want to move up on new tech. I admit LCD and plasma options are great when you are doing broadcast, blu ray, home viewing stuff. You see on same tech like people watching at home. But what about the DCP and film print. Even in Rec709 if you compare the blacks, they are not reproducing in same way on any of the technologies.
I have seen and tested a bit Sony’s OLEDs. They are great, specially in dark room, what I prefer for film work. But still I can not decide if it is so much better than LCD it just doesn’t feel the same like CRT comparing to projector.
OK let go back watching in my LCD 🙁
