Activity Forums Boris FX What will happen to my CS4 files?
  • What will happen to my CS4 files?
    Posted by Mark Rothman on August 3, 2010 at 8:26 pm
    If I upgrade to Premiere Pro CS5 can I still open CS4 files with Red 4.3 filters applied, or do I have to wait for the Red 5 update? Exactly how incompatible is 4.3.3 with CS5? It’s the only thing keeping me from upgrading!
    Peter Mcauley replied 16 years, 1 month ago 3 Members · 3 Replies
  • Matt Mullen
    August 4, 2010 at 1:58 pm
    Red 4 is not 64 bit therefore it will not install into CS5 currently.
  • Mark Rothman
    August 7, 2010 at 8:48 pm
    So what will happen if I open a CS4 file with a Red filter in CS5? Will it crash or just ignore the Red filter?
  • Peter Mcauley
    August 9, 2010 at 12:59 pm
    I suspect that the filter will simply be ignored and doubt that the presence of an unsupported filter in the timeline could cause a crash. You can always open the CS5 project with the caps lock enabled, which prevents on-screen rendering, and then navigate to the section where the RED filter is in the timeline and remove it before releasing the caps lock.
    Cheers,
    Peter.
