Activity Forums Apple Final Cut Pro Legacy what will be the best export quality?
  • what will be the best export quality?
    Posted by Chris Balogh on March 11, 2009 at 5:13 pm
    When exporting a timeline, what will produce better quality on a DVD, the Quicktime movie option (where it is a final cut pro file) or the Quicktime movie through the conversion option?
    Rafael Amador replied 17 years, 6 months ago 3 Members · 2 Replies
  • Aaron Stout
    March 11, 2009 at 5:30 pm
    Export directly to Compressor will give you the best results. This option will take over FCP until the export is complete because it goes through your timeline frame by frame. File > Export > Using Compressor
    If you want to still work on FCP while exporting, try exporting as a Quicktime reference file: File > Export > Quicktime Movie… and make sure the option “Make Movie Self-Contained” is OFF. You can then drop that exported file into Compressor and, while it’s chugging, you can still work in FCP.
    As the for the “best settings” you asked about, that’s done in Compressor. The “best” depends on how long your video is. The longer the video (+90 minutes) the lower the quality will be to fit it on a single DVD. (as DVD’s max out at 4.7GB) Any timeline under 90 minutes, just use Compressor’s preset – DVD: Best Quality 90 minutes
    – Aaron
  • Rafael Amador
    March 11, 2009 at 5:36 pm
    I agree with Aaron, the best is sending to Compressor from the FC time line. The problem is that when you make a Double Pass compression, everything must be rendered twice.
    I recommend you to export a Self-contained movie the less possible compressed, then to Compressor.
    If you export to a very compressed codec (DV) and them to MPEG-2 your picture will suffer a lot.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
