what went wrong? converting h264 to prores
I’m cutting h264 footage for the first time, from a Nikon D3300 and a Canon EOS 5D MK III. (And I have to say Nikon’s lower-end camera is really, really impressing me when compared to the Canon MKIII. But that’s unrelated.)
I used MPEG Streamclip to convert the footage to Pro Res 422. This is their post-conversion formatting info:
Nikon clips 59.94fps, resolution 1920×1080, data rate 34.4 mb/s
Canon clips 59.94fps, resolution 1280×720, data rate 15.9 mb/s
I’m cutting on Final Cut Pro 7.
THE PROBLEM I’M HAVING is that when I drag the Canon clips to the timeline I have to render them before I can view them. And now I’m at the fine-tuning stage, so what’s happening is I’m literally moving the clip a frame or two and then rendering for a minute. Then the clip is still not quite where I want it so I have to move it a frame or two and render all over again.
What should be a simple process is taking forever.
Does anyone know why this is happening? Is it because the Canon’s resolution is 720 and the Nikon’s is 1080? I thought that by shooting at 60fps on both cameras I could avoid problems like this.
Thanks in advance.
