What to do? Switch to Vegas?
Posted by Juan karlo De guzman on October 23, 2007 at 9:11 pmDon’t know what to do. I heard a news that was kinda true. Media Studio 8 will end.
Very sad. Anyway, here’s my computer specs. Search Google for Acer Aspire 5502ZWXMi or Acer Aspire 5502z .
I have a CD of Sony Vegas 6. Is Sony Vegas 7 or 8 available? Will it run on my PC?
Transferring from Media Studio Pro to Sony Vegas is I think difficult.
Anyway, do you think I made the right decision?
How can I be a PRO in Vegas in probably immediately? Or learn the basics?
Is Vegas worth it?
Ken Olson replied 18 years, 9 months ago 10 Members · 11 Replies -
Terje A. bergesen
October 23, 2007 at 9:59 pmDownload Sony Vegas 8 from https://www.sonycreativesoftware.com/. It is easy and intuitive. Go through some of the examples.
I switched from Media Studio 7 to Vegas 6 and have never considered upgrading Media Studio. I was too disgusted with the way Ulead treat their customers – they are still selling DVD Workshop, but haven’t had developers on the product for at least two years.
Neil Moxham
October 24, 2007 at 4:46 amVegas 6d is rock solid.
I think with an open mind willing to learn a different workflow…you will be amazed at how intuitive vegas really is.
Tools are where you’d expect them to be…everything is never more than 2 clicks away.
Let the program show you how to be efficient. Less time fussing and more time creating.
Many diehard avid, premiere friends of mine are using Vegas more and more for its fast (and pro) results.
The “Click count” is far less than competitors for the same result.!!! Almost 4 to 1
as we say in the audio world.
“Are you mixing or fixing?”Make the move …you wont regret it.
Zipedit -
Craig Cooper
October 24, 2007 at 11:13 amI first started with Pinnacle Studio. Then play’d around with Vegas 6 then 7, I’m now waiting for Vegas pro 8. Vegas has everthing you need now since having added a titler.
Go get yours…..
Craig
Codyjarrett
October 24, 2007 at 11:47 amJuan,
Those are all excellent questions.
I have been using Vegas for a number of years now on my home computer and it has been terrific. It is fast, flexible and after editing commercials professionally on Avid, I have found that Vegas provides a great, great home-system alternative.
Two things.
One, Vegas has a bunch of terrific features, but most of them require a fast computer. It makes a huge difference.
Two, I have just installed another 2 GB of memory to my system, bringing it up to 4GB. I think Vegas requires at least 2 and is much better with 4. The memory in your video card is important as well.
I think you can go to Vegas Pro simply because Vegas is also an easy system to learn and it’s very flexible. If you’re used to editing a certain way, it’s likely Vegas will allow you to continue to edit in a way you’re used to.
I’d say go for it.
Cody
Mike Kujbida
October 24, 2007 at 12:58 pmOne, Vegas has a bunch of terrific features, but most of them require a fast computer. It makes a huge difference.
Agreed. My quad core leaves my old P4 3.4 in the dust 🙂
2 GB of RAM is good but XP (if that’s what you’re running, won’t see 4 GB. AS I recall, 3 is the upper limit.
Unless you’re running the full version of Magic Bullet and one of their specified video cards, a decent dual-head card is all you need.
More memory on the card is good if you’re a gamer but otherwise it has no effect (with the exception noted above) on Vegas’s performance. -
Codyjarrett
October 24, 2007 at 6:21 pmHow about Vista?
Is it worth it upgrading to Vista in order to utilize 4 GB of physical memory – and thus, make Vegas run a bit smoother?
Is there any way to use more within XP??
thanks,
cody -
Rob Mack
October 25, 2007 at 1:35 amVista is 32-bit so you still don’t see the whole 4 GB. max you could see is someting like 3.12 GB, and if you put a fat video card in there with lots of onboard RAM you may see even less.
You can use XP or Vista 64 and then the OS will see the whole 4GB. Vegas, still being a 32-bit application, will probably not be able to use more than 2GB, but the OS gets more RAM to play with so it’s possible that Vegas would actually get to use the whole 2GB.
As far as migrating to Vegas, a big issue for all such migrations is getting old projects into the new edit system.
Rob Mack
Codyjarrett
October 25, 2007 at 2:00 amthanks, rob – that is definitely helpful. I’m just looking for ways to make vv run smoother, faster and crash less…
Don Smith
October 31, 2007 at 1:25 pmI was a user of MSP7 and upgraded to MSP8. I got sick of all the crashes whenever I scrubbed the timeline. MSP8 was very unstable for me, not to mention that it is dying off and isn’t supported by Ulead anymore. I have been using Vegas 7 for over a year and upgraded to Vegas Pro8. Vegas is rock solid stable, it is really hard to even try to make it crash. The learning curve was very easy coming from MSP8. And the more you learn about Vegas, the more you wish you switched earlier. My editing is MUCH faster, no crashes whatsoever, I can do more, it’s easier, and any MSP user should really make the switch. You won’t regret it.
Ken Mitchell
November 8, 2007 at 10:00 pmI still use media studio pro8. Corel customer service told me they are dropping it. I had already switched to vegas about 2 years ago. Use vegas 8 mostly with some help from msp8. There are still a few things that msp8 does quite well so it still generates income. At work I use MSP8,Premiere PRO CS3, Final Cut and Vegas.. .. Vegas is a great system to switch to.. You’ll figure it out.
