Activity Forums Adobe After Effects What to do with archival newspaper article
  • What to do with archival newspaper article
    Posted by Mary Gerber
    on October 29, 2012 at 7:21 pm
    Hi all!
    I work on a lot of historical non-fiction shows and use a lot of archival newspaper articles. Typically I just do a pan and zoom in after effects. I want to try something different, but not too time consuming. Has anyone out there come across an AE template that I could import the articles into to give them a different look within the show?
    Tudor “ted” jelescu replied 13 years, 10 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    October 30, 2012 at 12:01 pm
    You could create some simple templates yourself – create a solid the size of your articles and precomp that. Make the precomp layer 3d and play with position in Z space and rotation on the Y axis. Once done, duplicate that comp in the Project window as many times as you need it (the number of articles) and use it in a master comp. You can tweak the duplicate comps to have small differences in the animation.
    Tudor “Ted” Jelescu
    Senior VFX Artist
