Activity Forums Apple Final Cut Pro Legacy what to compress Apple OpenDML JPEG as?
  • what to compress Apple OpenDML JPEG as?
    Posted by Christina Rule on March 10, 2009 at 4:00 am
    I captured a bunch of footage from an xbox during game play.
    The format of the video files is
    .AVI
    Apple OpenDML JPEG,1280 x720, Millions
    16-bit Integer, little endian, stereo 48 Khz
    59.94 FPS
    I saw a previous post saying to use mpeg stream clip and export it out as DV. Obviously I am wanted to keep as much quality as I can but still be able to edit smoothly in FC… Im not sure what codec to export it as
    any help would be great thanks!
    http://www.christinarule.com
    Rafael Amador replied 17 years, 5 months ago 2 Members · 3 Replies
  • Rafael Amador
    March 10, 2009 at 4:52 am
    Hi Christina,
    Use MPGStreamclip but don’t export as DV. You will get a DV Stream, the kind of files used by iMovie.
    The best codec would be 8b Unc but this would made very files.
    I would recommend you to capture ProRess.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Christina Rule
    March 10, 2009 at 6:48 pm
    hey I dont think re capturing is an option… sadly… what do you think is my best option then?
  • Rafael Amador
    March 11, 2009 at 1:23 am
    Sorry Christina, I meant to export as Proress. That if you want to get the most quality from your XBOX files.
    Rafael
