Activity › Forums › Adobe After Effects › What the heck is “AfterFX.com”?
Posted by Shawn Lance on May 1, 2006 at 8:09 pmDidn
Brenden Wing replied 16 years, 5 months ago 3 Members · 3 Replies -
George Robbins
May 2, 2006 at 9:32 pmsorry no answer for you but I have the same problem… i’ve used illustrator as a work around but it’s a bit clunky.
never experienced this on OSX, just windoz
Brenden Wing
April 8, 2010 at 7:18 pmAfterFX.com is actually a setting found within the AfterFX Properties.exe (located in your support files of After Effects).
If you are having an issue with this, you more then likely have made a memory adjustment that your computer did not like.
Hope this helps.
