Activity › Forums › Apple Final Cut Pro Legacy › What specs do I need on my new Macbook Pro?!
Posted by Allan Hughes on June 15, 2010 at 9:23 pmBought a Sony NX5.
Going to be editing full HD – 1080i 30p. 1080i 24p. 1920×1080.
Plan on editing with FCP and After Effects.What specs do I need? This is what I planned out.
17″
2.66 GHz Core i7
8 gigs RAM
500GB 7200 rpmQuestions… can it handle well with 4 gigs or RAM? Should I substitute the hard drive with a Solid State hard drive, and forego the ram? What’s most important to run what I mentioned above? RAM? Hard drive? Processor?
Looking to spend no more than $3000.
Thanks all,
Allan Hughes replied 16 years, 3 months ago 3 Members · 6 Replies -
David Roth weiss
June 15, 2010 at 9:46 pmAlan,
Do a little searching and you will find that the same question was asked and answered yesterday and just about every day before that.
The 17″ MBP is the best of all the laptops because it is the only one that has and express card slot enabling a hard drive RAID. Which brings up the most important question, what do you intend to use for a media drive or RAID?
4Gb will do in a MBP and a solid state drive is an unnecessary expense.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Allan Hughes
June 15, 2010 at 10:04 pmHey Alan, sorry for the redundant question…. Just wanted to hear it directly from someone reputable. .
Great to know about the 4g RAM working just fine. I keep hearing that you need 8g if you plan on running After Effects with all HD footage. Can you confirm that?
Planned on just picking up a 1.5 terrabyte Lacie drive or something for the media drive. Would you recommend anything?
David Roth weiss
June 15, 2010 at 10:29 pmYou’re Alan, I’m David… Keep that in mind unless inflowing money is in question, in which case I answer to any name…
You would be far better off with a an eSATA RAID with at least two drives, which you would run off a SATA controller card in the express slot of the 17″ MBP. It will get you four to eight times the throughput of a single firewire 800 Lacie drive.
1Gb RAM per core will do you just fine. You will be far better off spending the money you save on the RAID I mentioned above.
David Roth Weiss
David Roth weiss
June 15, 2010 at 10:47 pm[Dave LaRonde] “Wow! You pro FCP cutters like to run AE lean on RAM. “
I suggest that in the long run, a cost/benefit analysis will indicate that a SATA RAID will improve day to day editing experience far more than an increase in RAM, so long as there is at least 1Gb per core.
David Roth Weiss
Walter Soyka
June 16, 2010 at 12:05 am[David Roth Weiss] “I suggest that in the long run, a cost/benefit analysis will indicate that a SATA RAID will improve day to day editing experience far more than an increase in RAM, so long as there is at least 1Gb per core.”
I’d agree with this statement for editing with FCP only, but Allan also specifically mentioned After Effects.
After Effects is extremely memory intensive. 4GB of total system RAM will be very, very tight for AE, especially working in HD. Multiprocessing in AE with 8GB is workable, but multiprocessing with only 4GB is out of the question. Skimping on RAM — thereby disabling AE’s multiprocessing — will nearly double render times.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Allan Hughes
June 16, 2010 at 7:52 pmLots of good info here. Thanks guys.
From what I’m gathering here. I’m looking at:17″
2.66 i7
8 gig RAM (to please AE5)
7200 rpm
eSATA RAIDSo all this eSATA RAID talk, I don’t know anything about. Would you recommend a specific model, size, speed for that macbook I listed up there? I’m sure they’re all good, but I’m sure there’re ones that have crapped out on you as well.
System Priorities:
EDITING FCP = Processor Speed / eSATA RAID drives.
EDITING AE5 = RAMgiven, everything is important, but those are the priorities here?
