Activity › Forums › Adobe Premiere Pro › What should the kbps export setting be set to?
Posted by Ryan Elder on December 13, 2019 at 6:02 amWhen it comes to kbps, what should the setting be set to when exporting if your audio was recorded at 24 bit/48 khz?
I tried looking it up but every tutorial talks about Mbps and not kbps. Does anyone know what the kbps settings should be?
Ryan Elder replied 6 years, 9 months ago 3 Members · 15 Replies -
Tero Ahlfors
December 13, 2019 at 6:51 amThe export bit rate doesn’t correlate with the original recorded format. Compressed audio usually goes from 16 to 320 kbps (at least with the AAC codec found in Premiere) and I unless otherwise specified I use the maximum because the audio bit rate still isn’t that much compared to what the video should be.
Ryan Elder
December 13, 2019 at 7:06 amOh okay thanks, this is what I thought, but I was just guessing. What about mbps? Some tutorials say to put it at 16, but should I? When I try to click on the properties of the original footage though, It does not list Mbps.
Tero Ahlfors
December 13, 2019 at 8:35 am[ryan elder] “What about mbps?”
Not usually used in specs with the common compressed audio formats so I dunno ¯\_(ツ)_/¯
[ryan elder] “Some tutorials say to put it at 16, but should I?”
I have no idea what these tutorials are trying to teach but 16 Mbps for audio would be quite a lot and 16 kbps would be kinda shitty. Maybe they meant bit depth?
Ryan Elder
December 13, 2019 at 8:41 amAs for ‘bit depth’, it’s not called that in premiere pro, it’s just called Target bitrate, or mbps.
Todd Perchert
December 13, 2019 at 4:24 pmI’ll be honest Ryan, it sounds like you are mixing up audio settings with video settings. There is a bit depth in video and audio, but they are two separate things. Bit depth in audio is number of bits in a sample – or something like that. Bit depth in video usually refers to color information. Both of which I don’t think you need to worry about when exporting from PPro.
Audio, as stated by Tero, usually has a bit rate of 16-320kbps, but can go higher. Video bit rate usually is specified by Mbps, and if you are using a variable bit rate for video, you can select your Target bit rate and Maximum.
Hope that helps!
TC -
Todd Perchert
December 13, 2019 at 4:28 pmAnd as far as your original question… I usually export my audio at 48KHz High Quality AAC at 320Kbps for masters. For viewing files that I may email, I may take the audio bit rate down to 192Kbps and I compress the video down to around 1.5Mbps 720p.
TC -
Ryan Elder
December 13, 2019 at 4:54 pmOh no, I didn’t mean to imply I was getting them mixed up. I just meant that now that we have established how high to set the kbps, how high should I set the mbps after?
Todd Perchert
December 13, 2019 at 7:08 pm[ryan elder] “how high should I set the mbps after?”
That kind of depends on your delivery specs. Where are you sending the video?
TC -
Ryan Elder
December 13, 2019 at 7:11 pmOh okay thanks. Well I am uploading it to filmfreeway, to send to festivals. So if it’s the filmfreeway copy, then what is the best?
