Activity › Forums › VEGAS Pro › What should computer settings be for vegas 7?
  • What should computer settings be for vegas 7?
    Posted by Dave Petteruto on May 10, 2007 at 5:54 pm
    Hello All,
    I am starting off with a fresh computer (new hard drives & windows install in a 2 1/2 year old machine) and I would like to know what my settings should be to let Vegas 7 run as smoothly as possible. Things like DMA on or off, do the 1394’s need to be disabled, indexing on or off, etc. Also what Vegas settings need to be changed? Any info would be much appreciated.
    Thanks & hope you all have a great day.
    Dave P.
    Ralph Hajik replied 19 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • Edward Troxel
    May 10, 2007 at 5:59 pm
    [dpetto] “Things like DMA on or off,”
    ON
    [dpetto] “do the 1394’s need to be disabled”
    No. You use firewire to capture video
    [dpetto] “indexing on or off”
    I prefer OFF
    Edward Troxel
    JETDV Scripts
  • Randall Raymond
    May 10, 2007 at 6:11 pm
    Create a small partition on your main drive – say 10gig or so – and tell windows to put your page file there (‘D:’ drive) that will help keep fragmentation down and speed things up.
    Also make sure to set the size of the page file – 10gig in this example – if you let windows set the size – that will slow things down as it first determines how much room it has to write its temp files.
  • Dave Petteruto
    May 10, 2007 at 8:08 pm
    Are there any other settings anyone can think that I should be concerned about? What about memory allocation in Vegas itself?
    Dave P.
  • Dave Petteruto
    May 10, 2007 at 8:13 pm
    “Create a small partition on your main drive – say 10gig or so – and tell windows to put your page file there (‘D:’ drive) that will help keep fragmentation down and speed things up.
    Also make sure to set the size of the page file – 10gig in this example – if you let windows set the size – that will slow things down as it first determines how much room it has to write its temp files. “
    How is this done? Is it something that I can do fairly easily with some instruction?
    Dave P.
  • Edward Troxel
    May 10, 2007 at 9:14 pm
    10 Gig seems extreme for the pagefile. I haven’t had issues letting Windows handle it. It shouldn’t be on the same drive as your video files anyway.
    Edward Troxel
    JETDV Scripts
  • Edward Troxel
    May 10, 2007 at 9:15 pm
    The defaults are a good start. I would only up the ram preview if you’re needing to do a ram preview on a larger area. Afterwards, I’d take it back to the default.
    Edward Troxel
    JETDV Scripts
  • Randall Raymond
    May 11, 2007 at 1:56 pm
    [dpetto] “How is this done? Is it something that I can do fairly easily with some instruction?”
    It’s easily done – but I’m not sure you can add a partition with windows already running. I’ve always done it before installing windows.
    I also create a third partition called ‘My Documents’ and use that like a big folder.
    If you aren’t running ‘Diskeeper’ – you should. It’s an amazingly effective program to keep all your drives frag-free. Well worth the price of 50 bucks.
  • Randall Raymond
    May 11, 2007 at 2:07 pm
    [jeditdv] “10 Gig seems extreme for the pagefile. I haven’t had issues letting Windows handle it. It shouldn’t be on the same drive as your video files anyway.”
    I also use the pagefile partition for my downloads and temp files.
    My disk is set up like this:
    C: windows and programs 100g
    F: pagefile 20g
    G: all content except video 115g
    250g drive total
    I have 8 drives total
  • Ralph Hajik
    May 11, 2007 at 2:18 pm
    Hello All,
    I keep all my running programs on my C drive 250 gig., music on my D drive 250 gig., Veg and rendered DVDA files on my external hard drive 500 gig. I’m working towards appling another drive so I can separate my veg files and my rendered DVDA files.
    Ralph Hajik
