Activity Forums Apple Final Cut Pro Legacy what settings to use
  • what settings to use
    Posted by Greg Ball on November 3, 2012 at 5:02 am
    I have a client who is giving me 1920×1080 footage converted from MTS files and also a DVD that’s 720×480 letterboxed. I need to use all footage in a timeline and output a 720x 480 quicktime file.
    I’ve converted everything to pro res 422. The majority of the footage is 1920×1080. Would you edit in a 720 x480 timeline? In doing so all the 19201080 footage is red lined and needs to render to play it.
    Which way would you go here? Thanks.
    Chris Tompkins replied 13 years, 9 months ago 4 Members · 3 Replies
  • Nick Meyers
    November 3, 2012 at 9:05 am
    “RED LINED” is a warning.
    there is something wrong with your settings.
    could be frame rate is off,
    could be a dodgy codec (like H264 or something) oh, you say everything is PR422?
    then frame-rate
    have a closer look at your clip’s settings vs your timeline settings,
    report back.
    in theory working in a 720×480 timeline is the way to go
    is it ALL red line?
    nick
  • Justin Keating
    November 3, 2012 at 9:45 am
    I’d edit in a 720/480 sequence. That way you can re-position your HD footage knowing what it will ultimately look like in the frame. Plus you won’t be stretching (and then down-scaling) your smaller footage.
  • Chris Tompkins
    November 5, 2012 at 2:19 pm
    You’ll need to render that HD material in an SD sequence.
    Edit in an SD final size sequence.
    Watch your field orders.
    Chris Tompkins
    Video Atlanta LLC
