Activity Forums DVD Authoring What settings should I
  • What settings should I
    Posted by Dan Weinberg on May 6, 2009 at 7:17 pm
    I have been creating menus using still photos and text in Photoshop and
    then importing them into DVD SP. Once I do this however the image
    becomes distorted because the DVD SP project uses rectangular pixels,
    while Photoshop uses square.
    I have tried different settings in Photoshop: (D1/DV NTSC Widescreen, NTSC D1/DV Anamorphic,
    Film/Video setting at 720 x 480, 720 x 540.
    Nothing seems to be working.
    What am I doing wrong, and what can I do to solve this?
    Michael Sacci replied 17 years, 4 months ago 2 Members · 1 Reply
  • Michael Sacci
    May 7, 2009 at 12:05 am
    Just use the Photoshop preset for DV/NTSC, if you want/use anamorphic you need to set the display aspect in DVDSP menu inspector to 16:9 Letterbox (or 16:9 Pan and Scan) If you want a full screen 4:3 do not select anamorphic.
