Activity › Forums › Adobe After Effects › What settings should I use for FCP anaporphic sequence?/ Online editing?
  • What settings should I use for FCP anaporphic sequence?/ Online editing?
    Posted by Paul01 on May 15, 2005 at 4:12 am
    Can anybody help me and tell me what setting I should use so that I can import After Effects Title into an anamorphic sequence on FCP?
    I am doing very simple titlework. What should I consider, so we don’t run into problems when finishing and onlining? Can I just burn the titles onto a cd and give that to them? (finishing will be on Avid)
    Thanks.
    Steve Roberts replied 21 years, 4 months ago 4 Members · 3 Replies
  • Barend Onneweer
    May 15, 2005 at 11:12 am
    Well, it all depends on the finishing format and settings. If it’s NTSC throughout the production, and there’s no plan to up-res to some flavour of HD, chances are that the project is finished in NTSC anamorphic widescreen, and those would be the settings to use.
    But it’s really a matter of getting more information.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Ralph Keyser
    May 16, 2005 at 10:45 pm
    With the danger of hi-jacking this thread, can someone explain NTSC anamorphic widescreen? I understand it for film (I think). You use special lenses when you shoot that squeeze a wider view onto the film than normal, then matching special lenses when you project to return the wider view to the screen. If you were to look at the film shot with these anamorphic lenses, things in the image would be too tall and skinny. So, how does this work with NTSC given that there is no special lens to return the image to “normal”?
  • Steve Roberts
    May 17, 2005 at 3:47 am
    Computer monitors use square pixels. As a result, 640 pixels by 480 pixels on a computer screen looks 4:3, as you’d expect.
    However, the NTSC TV spec calls for 720 pixels by 480 (or 486) pixels to look 4:3 on a TV.
    Huh? 720×480 is not 4:3. Wassup?
    This actually works if the pixels are not square. In this case, the pixels are tall rectangles, so 720×480 works out to 4:3. So when a 720×480 image is played on a TV, the image looks right, because it displays tall pixels.
    DV widescreen (or 16:9, not anamorphic) is also 720×480 pixels, but the pixels are not square, nor are they tall. They are actually wide: 1.2 to 1. However, if you tell AE that the footage is NTSC widescreen, it interprets the footage properly. Look in the help under “pixel aspect ratio correction” for more info.
    So it’s not lenses, it’s pixel aspect ratio: square, tall, or wide.
    Check out this article by Rick Gerard.
    There’s also more info in the help. Search using “widescreen” and “pixel aspect ratio correction”, as mentioned.
    Steve
