Activity › Forums › Adobe After Effects › What setting to export?
Posted by Randall Murphy on April 14, 2007 at 10:52 pmI’m creating a DVD and authoring it in encore. There are tons of exporting options in AE and so many different results. What is the best/cleanest option for exporting?
Randall Murphy replied 19 years, 5 months ago 2 Members · 3 Replies -
Steve Roberts
April 15, 2007 at 3:38 pmWork backwards from DVD:
DVD needs a movie compressed to MPEG-2. Create that in Encore or similar compression app.
Encore needs uncompressed AVI to make that MPEG-2. Create that in AE.If not uncompressed AVI, create a similar high-quality movie using the Animation codec in Quicktime, or an 8-bit uncompressed codec if you have it.
Make sure you’re in the right size preset: 720×480 DV if you’re in NTSC.
Anyway, render using the render queue and make it as high quality as possible at the specified frame size.
Randall Murphy
April 16, 2007 at 2:30 amWhen I export the AVI, it plays very jittery. What can I do to make it smooth and clean?
Randall Murphy
April 16, 2007 at 2:45 amMy bad, it was too low a frame rate, however, there are small lines that come in and out of the picture, like around the subject eyes. Is there any way to clean that up?
Thanks Steve for your input. That clears things up for me. I’m in San Diego but spent two months out of the year in Brampton with a client last year.
