Activity › Forums › Apple Final Cut Pro Legacy › what setting in FCP 6 to import hdx 900 footage shot at 24p
  • what setting in FCP 6 to import hdx 900 footage shot at 24p
    Posted by Frederic Menou on January 27, 2010 at 3:50 am
    Hello all,
    I shot some footage with the panasonic hdx 900 at 1080 24p (not 24pa) and want to import it in FCP 6 using firewire and the panasonic deck.
    Simple question: what setting should I use in FCP for the import?
    I don’t see the 1080p 24?
    (Also I want to cut that footage with some that I shot with the varicam at 720 24p. So I want the frame rate to match…)
    Thanks for your help
    Rob Grauert replied 16 years, 8 months ago 2 Members · 1 Reply
  • Rob Grauert
    January 27, 2010 at 1:16 pm
    I believe 24p has pulldown added to make it 60i. Therefore, you’d capture 1080i60.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
