Activity › Forums › Apple Final Cut Pro Legacy › What Setting for Still Images?
  • What Setting for Still Images?
    Posted by Jm Knowles on September 28, 2008 at 2:38 am
    I am editing a piece that will be projected on a screen from a computer. It is mostly still shots that I am zooming in on.
    Something has happened and when I render I get a lot of nasty scan lines. I have gone into sequence settings – quicktime and set it to none.
    When I go into Audio Video settings I see a bunch of choices for sequence presets. Is it a setting here I am looking for? Which would I choose (considering the source are still images).
    Any help is appreciated!
    jmk
    Jm Knowles replied 18 years ago 2 Members · 2 Replies
  • Richard Harrington
    September 29, 2008 at 1:09 am
    Well…
    However you intend to play back video… make sure your settings for sequence match
    i.e. if its 1024 X 768.. use that…. do not have fields… make sure motion filtering is set to best
    you will have no real time playback at these custom settings though…. so you might want to build first with another square pixel preset (like pro-res square pixel.. then convert)
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Jm Knowles
    September 29, 2008 at 3:21 am
    Thank you Richard
