Activity Forums Apple Final Cut Pro Legacy What Sequence Settings should I use?
  • What Sequence Settings should I use?
    Posted by Alberto Mendez on September 23, 2010 at 4:48 pm
    The majority of my project is HDV footage (70 hours total).
    -50 Hrs HDV Shot on Sony V1U@24P (1440 x 1080)
    -20 Hrs HDV Shot on Sony Z1U@30i (1440 x 1080)
    I know I can convert the HDV footage to native apple pro rez 422 but I don’t want to spend forever transcoding. I have already been working with the HDV footage in doing stringouts and selects as well. I also have other types of footage that I will be throwing in my timeline like the following.
    Cannon 5D footage (15 hours total)
    -7 Hrs@30P (1920 x 1080) H.264 Codec
    -8 Hrs@24P (1920 x 1080) H.264 Codec
    SD Footage
    -8 Hrs DigiBeta
    -6 Hrs Mini-DV
    As far as editing my documentary film, the majority of it will be cuts and dissolves only. What timeline should I be using as far as sequence settings? Ultimately, this will be mastered to HDCAM SR. Any advice will be greatly appreciated.
    thank you.
    Shane Ross replied 15 years, 11 months ago 2 Members · 1 Reply
  • Shane Ross
    September 23, 2010 at 6:16 pm
    I’d leave the HDV as HDV…just edit it into a ProRes timeline. It will do good there. But Dave has you right on the other points.
    In the future, avoid shooting multiple frame rates. That is a BAD IDEA. Mixing frame rates, not matter what Apple Marketting says, doesn’t go well in FCP.
    Shane
