Activity Forums Apple Final Cut Pro Legacy What Sequence settings for Apple OpenDML JPEG?
  • What Sequence settings for Apple OpenDML JPEG?
    Posted by Sean Kapleton on February 21, 2008 at 3:40 pm
    I shot a bunch of footage using my Canon SD800 which has a video camera mode – obviously the quality is super low but its ok because this project is for a user populated site and it actually helps that it looks home made.
    The format of the video files is .AVI but when i get info on the QT it says the following:
    Apple OpenDML JPEG, 640 x 480, Millions
    8-bit Unsigned Integer, Mono, 11.024 Khz
    30 FPS
    I have the most recent version of FCS 2 and I need to deliver my final edit of this project for the web with these any compression as long as its 640×480.
    I am hoping to prevent loosing any more quality on the picture so I onbiously dont want to compress / transcode in any way if possible. When i bring the clips into a sequence FCP does not give me the window asking if i want to convert the sequence to match the clip – I believe that is because the format is not supported by FCP but obviously it IS an AVI so i can view the clip within FCP.
    Any help would be great
    thank you
    sean
    Vickie Sampson replied 15 years, 10 months ago 7 Members · 8 Replies
  • 8 Replies
  • David Roth weiss
    February 21, 2008 at 5:18 pm
    Just run the clip into Streamclip and turn it into a QT DV file. DV compression won’t do anything appreciably funky to funky video.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Sean Kapleton
    February 21, 2008 at 6:38 pm
    I thought that as soon as you take it through another step it loses some quality – My next question is why would i use DV when i could use animation or Photo JPEG? Also why use Steamclip when i have QT Pro and/or Compressor?
    I am interested to hear your response as well as the opinions of others in this forum
    thank you
    sean
  • David Roth weiss
    February 21, 2008 at 6:47 pm
    Streamclip is free and it handles AVIs and many other non Quicktimes very nicely and very quickly.
    You can convert to any QT format you like, but typically really grizley video shows no wear when going through DV compression. DV compression performs its worst magic on pristine text and graphics.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Joon Pontén
    May 4, 2008 at 9:51 pm
    Is there really no way to get around the conversion, which takes some time? I would typically prefer to work in the format it was shot in, and as it’s really not a gigantic dataflow I would think FCP could handle that?
    What IS Apple OpenDML JPEG – a motion JPEG flavour or…? And why can QT Player play it without any problems, while FCP throws the red bar in my face?
    Would be grateful for any clues on this, as I will be starting a project soon…
  • Rafael
    May 17, 2008 at 6:05 pm
    That is a very interesting question. I shot also with my little Canon camera SD870. When I open iMovie ’08 it scans the hard drive in 1 minute and finds all the clips and doesn’t recompress!
    So, I am using the export feature in iMovie >Share>Export to FInal Cut Pro XML.
    But then when I opne via inport in Final Cut Pro 5.1.4, it imports the equence, but I can’t find to match the settings of my sequence to iMovie. But if I drag one of these .avi movies from my Canon into FCP, it plays in real time, no need to render. But only in my sequence, it seems that I have to render before playing.
    I found iMovie pretty fast to derush these hundreds of Canon files, so that’s why I use it, as well my wife is OK with iMovie but doesn’t know how to use FCP.
    Any thoughts?
  • Joseph Banks
    August 20, 2009 at 7:00 pm
    Here’s a way to get your OpenDML jpeg clips into an FCP sequence without rendering, but you do have to convert the files to Quicktime first:
    Convert to Quicktime with these settings:
    Compressor: Photo JPEG
    Quality: Best
    Frame rate: 30
    Dimensions: 640 x 480
    Audio 11.024kHz, 8-bit, mono (or whatever is native to the clips)
    Import the Quicktime files into your FCP project. Create a sequence with the following settings (copy a preset, set new parameters and rename it):
    640 x 480 NTSC 4:3
    Pixels: square
    Field dominance: None
    Audio: 48Khz, 16-bit, channel grouped
    Open each clip in the Viewer and drag it into your sequence timeline. When I did this there were no red bars and I was able to edit multicamera video tracks with no rendering, but when I tried dragging the clips directly from the browser instead – red bars. Go figure.
  • Jon Burton
    May 4, 2010 at 8:42 pm
    Thanks, this seemed to work.
  • Vickie Sampson
    November 10, 2010 at 7:25 pm
    I did everything exactly as you said but I still get the red bars. I’m using movie files from my canon A610 and they come in as mvi jpeg. Apple open DML jpeg 320X240.
    I even tried going thru streamclip but i still get the red bars. I’m also on a powerbook G4 10.4.11 using final cut academic 6.0.6
    any help is most appreciated!
