Activity Forums Apple Final Cut Pro Legacy What seq setting for DVCPRO HD
  • What seq setting for DVCPRO HD
    Posted by Ciller on February 20, 2007 at 2:06 pm
    I am an online editor and am about to online a programme for the first time off DVCPRO HD which was shot on Varicam. Im using a Macpro with FCP studio and an AJA Kona card and external G-raid drives this setup is usually perfect for me as im usually working with Digi beta but as i ve never worked with the HD format before im wondering if it ll do. any help for this HD virgin would be greatly appericeated
    Cheers
    Ciller
    Walter Biscardi replied 19 years, 7 months ago 3 Members · 2 Replies
  • Shane Ross
    February 20, 2007 at 5:18 pm
    Which Kona card? What do you need to output to? Has the footage already been captured at DVCPRO HD resolution?
    I simply color correct the DVCPRO HD footage, then output it to tape using the Kona 3. But we need to cross convert from 720p to 1080p.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Walter Biscardi
    February 20, 2007 at 6:32 pm
    [ciller] “Im using a Macpro with FCP studio and an AJA Kona card and external G-raid drives this setup is usually perfect for me as im usually working with Digi beta but as i ve never worked with the HD format before im wondering if it ll do. any help for this HD virgin would be greatly appericeated”
    Just use the DVCPro HD Easy Setup to match your footage. You can capture either with the AJA Kona board, which is what we do now, using the AJA Kona 720/59.94 DVCPro HD Easy Setup.
    Or, if you want to capture Firewire, simply choose the DVCPro HD 720/60 Easy Setup and switch your Playback to the AJA Kona card.
    If you have the Kona 3, you can cross convert your 720 to 1080i either during Ingest or during mastering.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
